Code 45 Fuel System too rich I searched
My car is a 01 GSR. I have a Vortech Supercharger and 310cc injectors and a Vortech FMU.. I keep throwin this code 45 fuel system too rich. is this because I just have the FMU? Another thing. Can I use obd1 gsr injectors for an obd2?
Im trying to put the car back to stock.
My guess is you are running a super rich basemap via the FMU and larger injectors. Pull the FMU, injectors and supercharger and you will likely get rid of the code.
In order to keep your setup and get rid of the code, you need to tune the ECU/FMU to not run so rich, aka wideband O2 sensor and proper engine management.
You should be able to use any saturated 240cc injectors (Most civics/integras) for a stock application.
http://turbod16.com/viewtopic.php?f=7&t=19966
