TYPE R Conversion
or you can save tons of money and just get the spoon calipers for your car!
Edit, I take that back....
You use those same r calipers and get some special rotors from spoon!
From spoons website
So you get those calipers, the front rotors listed above, but they recommend that you get larger rear rotors and special rear calipers.
[Modified by tonyxcom, 11:16 PM 6/25/2002]
From spoons website
Installation for DC2R ('96 specification), EG6, and EK4:
Although this caliper product has been specially developed for the EK9 and DC2R ('98 specification) 15-inch rotor, it can also be used for the DC2R ('96 specification), EG6, and EK4 if the front rotor is replaced. Furthermore, in accordance with the setting of front and rear brake distribution and P valves, it is recommended that the size of the rear calipers and rear rotors be increased. EK9 and DC2R ('98 specification) brake pads will be required; furthermore, when installing on a normal-configuration aluminum body, a spacer of approximately 15 mm will be required.
Rear-caliper set for four-pot aluminum calipers
Product code
45018-DC2-000 Rear-caliper set for EK9, DC2R(98SPEC)
15-inch brake rotor for four-pot aluminum calipers(Front)
Product code
45251-4H100 4HOLE PCD100
14-inch brake rotor for four-pot aluminum calipers(Rear)
Product code
42510-4H100 1 4HOLE PCD100
Product code
Product code
Product code
shinchan
Jan 15, 2003 03:34 PM
