Question Regarding the Third Lobe - Swirl Inducer
Old Nov 27, 2007 | 06:47 AM
Chillinit's Avatar
Default Question Regarding the Third Lobe - Swirl Inducer
It has been stated many times within this forum that the third lobe on a vtec cam shaft induces swirl of the incoming air/fuel mixture. I understand the reasoning for this however I'm not sure on how it is achieved.
Can someone shed some light on the subject?
Thanks in advance.
Old Nov 27, 2007 | 08:41 AM
King V's Avatar
Default Re: Question Regarding the Third Lobe - Swirl Inducer (Chillinit)
You get more swirl from the low speed lobes because they open something like 10 degrees apart. The 3rd lobe is the high speed lobe. This is the first mention I've heard of the 3rd lobe imparting swirl, unless what you're talking about isn't "standard" VTEC.
Old Nov 27, 2007 | 12:04 PM
Aquafina's Avatar
Default Re: Question Regarding the Third Lobe - Swirl Inducer (King V)
3rd lobe is VTEC. Valves open at the same time, no swirl.
You can see for yourself pretty easily. Get a round glass. Put two funnels over the top of it. One funnel with a bigger spout than the other to simulate the valve that is open more. Put some food dye into two glasses of water. Pour water evenly into both funnels and watch how the food dye mixes in the glass being filled. Not the best way, but it works.
Old Nov 27, 2007 | 01:03 PM
King V's Avatar
Default Re: Question Regarding the Third Lobe - Swirl Inducer (Aquafina)
I remember reading something about the VTEC in the 01-05? Civic Si and somehow the two intake valves can be opened one first, then both, then both a little more for "VTEC"? It might not be that car( i can't find the article right now), but apparently there is a Honda engine that works in that manner.
Old Nov 27, 2007 | 03:43 PM
Aquafina's Avatar
Read up on VTEC-E.
Old Nov 27, 2007 | 11:30 PM
92TypeR's Avatar
FSAE
Primary lobes induce swirl.
VTEC lobe induces tumble.
Old Nov 28, 2007 | 04:03 AM
Chillinit's Avatar
Default Re: Question Regarding the Third Lobe - Swirl Inducer (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Primary lobes induce swirl.
How does the Primary induce swirl?
Also, does the smallest lobe (First lobe) play any role in this?
Old Nov 28, 2007 | 05:38 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">
King V nailed it, each primary has a different valve opening and closing, this degree of separation causes air to swirl in the direction of the first valve's opening.
Old Nov 28, 2007 | 05:56 AM
night's Avatar
look up the D15B as well. 2 stage vtec.
Old Nov 28, 2007 | 08:14 AM
King V's Avatar
Default Re: Question Regarding the Third Lobe - Swirl Inducer (night)
The D15 has a two stage valve system, I've read. Somthing like 12 valve mode and 16 valve mode.
Old Nov 28, 2007 | 08:48 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">The D15 has a two stage valve system, I've read. Somthing like 12 valve mode and 16 valve mode.</TD></TR></TABLE>
I believe the k20a3 in base RSXs and 02-05 Civic Si's works in a similar way.
unknown420
Jun 24, 2010 07:11 AM
Miracle
Honda Civic (2001 - 2005)
74
Feb 26, 2010 07:30 AM
turboITR#704
Apr 24, 2008 12:14 PM
Historyg
Sep 25, 2007 08:42 AM
b16a27
Oct 16, 2004 01:59 PM
