Difference in H22a1 and H22a?
Old Nov 26, 2007 | 05:35 PM
All Mighty's Avatar
Default Difference in H22a1 and H22a?
Hey all. I tried searching but to no result. I am rebuilding my H22a. Can I use USDM H22a1 parts? Or do i have to use straight JDM H22a parts such as rings, bearings etc etc? I know H22's have two different pistons in it and all that. Just wondering if I can use USDM H22 parts instead of paying a **** ton for JDM parts.
Thanks guys
Old Nov 26, 2007 | 05:45 PM
95greenlude's Avatar
Default Re: Difference in H22a1 and H22a? (All Mighty)
yes, h22 and h22a1's parts are interchangable
Old Nov 26, 2007 | 05:49 PM
All Mighty's Avatar
Default Re: Difference in H22a1 and H22a? (95greenlude)
even internal wise? Can I still use H22a1 rings, bearings, and everything on a JDM H22a? That would save me alot of money
Old Nov 26, 2007 | 05:53 PM
i'm not 100% sure, but i believe they can be
Old Nov 26, 2007 | 05:54 PM
snobordboy's Avatar
Moderator
Yeah the only difference should be piston height, even your rings should be the same, and obviosuly make sure you hone to spec and set ring gap properly.
Old Nov 27, 2007 | 02:54 AM
All Mighty's Avatar
Thanks guys. I will be tearing it down within two weeks. So lets hope H22a1 parts match H22a
Old Nov 27, 2007 | 05:28 AM
Si Speed's Avatar
Default Re: (snobordboi)
Right. Piston height is the only difference. I've heard the cams are slightly different and heard they're the same but I'm not sure. Never had any to compare myself.
Old Nov 27, 2007 | 07:10 AM
Televator's Avatar
Default Re: (All Mighty)
Do you know what year your H22A is? 98+ will have larger mains than an H22A1. Although, you may not need to worry if you are just swapping pistons and rods.
Old Nov 27, 2007 | 08:43 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snobordboi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the only difference should be piston height, even your rings should be the same, and obviosuly make sure you hone to spec and set ring gap properly.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Speed &raquo;</TD></TR><TR><TD CLASS="quote">Right. Piston height is the only difference. I've heard the cams are slightly different and heard they're the same but I'm not sure. Never had any to compare myself. </TD></TR></TABLE>
Piston height?
You mean compression height?
If so, you're wrong.
The difference is the displacement of the dome. (jdm are 1.7cc IIRC)
Old Nov 27, 2007 | 06:01 PM
All Mighty's Avatar
Default Re: (Televator)
The H22a is pre 98.
Old Nov 27, 2007 | 06:02 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All Mighty &raquo;</TD></TR><TR><TD CLASS="quote">The H22a is pre 98.</TD></TR></TABLE>
You're asking the questions. We're giving the answers.
Old Nov 27, 2007 | 06:18 PM
All Mighty's Avatar
haha I know I know. Should I just go ahead and buy H22a rings, bearings and such. Then stuff like full gasket set, oil pump, water pump etc etc be purchased for an H22a1 for cheaper?
ej_jake
Mar 12, 2016 05:39 PM
DOHCMonster410
Jan 5, 2009 02:14 PM
BoostdRex
Aug 28, 2007 02:41 PM
elnoyl
Jun 2, 2003 02:04 PM
