Power window issue
My drivers side power window will not go up. I can hear the motor going, but the window doesnt follow.
Did it just fall off track? If so, is it hard to fix?
Anybody experience this?
Just take off the door panel (carefully) and you will be able to see all the window stuff...should be easy to see what happened if you do that.
i did, and i remove the regulator assembly. the teeth are worn down on the motor. could i just replace the cog(gear) or do i need the whole new assembly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dicorp »</TD></TR><TR><TD CLASS="quote">i did, and i remove the regulator assembly. the teeth are worn down on the motor. could i just replace the cog(gear) or do i need the whole new assembly?</TD></TR></TABLE>
I mean the OP should take off his door panel, but oh well
It looks like you would probably have to order the whole motor:
http://www.hondaautomotivepart...INDOW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dudeitsahonda »</TD></TR><TR><TD CLASS="quote">can u push it up ?
does it not work at a certain range?
i had broken/grinded down teeth b4 . changing it was no problem</TD></TR></TABLE>
I can push the window up and down without any real resistance. The window will not function using the button what so ever.
I took it apart last night and I tried to line up the teeth again with the regulator I am assuming and it tried to go up, but it wasnt grabbing correctly.
Is it expensive to replace this part?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR »</TD></TR><TR><TD CLASS="quote">does the gear on the motor spin when you try to roll up/down the window?
Yes the motor spins. It seems like its not grabbing anymore. I tried to align it back with the teeth, but no luck.
My power window doesn't work but i could here the motor i thought the regulator assembly is faulty i got another one the doesn't work either so i been told that it s a switch problem i got a switch still nothing. what could be wrong please help!!!!!
same thing happened to my civic's pass side and the window had fallen off of the track...just put on back on the track and worked good....i think my passenger slammed my door too hard or something
djfob
May 8, 2006 02:09 PM
full Circling
Jul 6, 2005 07:56 AM
EX-T
Dec 2, 2003 03:53 PM
