OBD0 to OBD1 Distributor Swap, possible?
Old Nov 26, 2007 | 01:23 PM
TurboAngst's Avatar
Default OBD0 to OBD1 Distributor Swap, possible?
Does anyone know if an OBD1 Distributor will work in an engine that is OBD0 compliant?
Specificly: A Distributor from a 92 Integra to an 89 Integra.
Is there a specific type of distributor that is OBD1 that will work in the 89 DOHC?
Old Nov 26, 2007 | 09:46 PM
quik1's Avatar
Default Re: OBD0 to OBD1 Distributor Swap, possible? (TurboAngst)
They are interchange able from b18a - b18b.
Old Nov 26, 2007 | 10:40 PM
civicstar's Avatar
you would have to get a conversion harness to make it work or rewire it
Old Nov 27, 2007 | 04:10 AM
mmuller's Avatar
Mad Scientist
no you cant use them unless you match the ecu with it.
obd1 and 2 = same
obd0 and obd1 not the same as far as ecus like
Old Nov 27, 2007 | 06:07 AM
91DA9's Avatar
Default Re: OBD0 to OBD1 Distributor Swap, possible? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">no you cant use them unless you match the ecu with it.
obd1 and 2 = same
obd0 and obd1 not the same as far as ecus like</TD></TR></TABLE>
Yeah, I definitely had an OBDII CR-V distributor running with my OBDI converted Integra. I believe one of the sensors has a different number of teeth or something that prevents using an OBDI dizzy with an OBD0 ECU.
Old Nov 27, 2007 | 07:42 AM
quik1's Avatar
Default Re: OBD0 to OBD1 Distributor Swap, possible? (91DA9)
Sorry I just ment that they would bolt in but yah there is some wiring for sure.
Old Nov 28, 2007 | 07:52 AM
TurboAngst's Avatar
Thanks for the info but I feel I didn't provide enough information.
I have a 91 EF Si
It has a D16 89 Integra Motor currently running a OBD0
I have in my possesion but not installed a P28 ECU
I am planning to purchase a OBD0 -&gt; OBD1 conversion harness
My problem currently is that I need a Distributor that will fit the 89 teggy motor but will also work an OBD1 ECU and Harness.
Sorry for not being more clear in my first post.
Old Nov 29, 2007 | 10:36 AM
TurboAngst's Avatar
Anyone Please?
Old Nov 29, 2007 | 04:02 PM
CoreyR's Avatar
we just put a B18A (OBD0) distributor on a JDM DOHC ZC motor. only the lower ear doesnt line up to the bolt holes but the other 2 do. all B18's have the same bolt pattern and if im not mistaken the head on the 88-89 D16A's are the same as the JDM ZC heads.
youll have to manually wire the cam postion sensor into the distributor plug of course since its external on those motors. or you can leave it and just rewire the dizzy plug without the cam sensor wires.
Old Dec 2, 2007 | 05:28 AM
TurboAngst's Avatar
Default Re: OBD0 to OBD1 Distributor Swap, possible? (CoreyR)
I'm guessing then a distributor from a 93 integra will intergrate with my d16a with a little modification?
Old Dec 2, 2007 | 07:21 AM
gibsanez's Avatar
You could just get a brand new one that fits perfect for $180 with a limited lifetime warranty
http://cgi.ebay.ca/BRAND-NEW-8...wItem
Old Dec 2, 2007 | 10:29 AM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboAngst &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing then a distributor from a 93 integra will intergrate with my d16a with a little modification?
i forgot to mention you also have the replace the cam cap that the dizzy bolts to on the top with one from an B18. the one on the ZC is shorter. the B18 one bolts right in. yes the 93 one will work, and year 90-01 will physically bolt up, the only diff are the OBD levels. anything 92-95 will work for you.
ryanangelo212
Mar 18, 2013 12:23 AM
viking-101
10
Feb 22, 2012 01:46 PM
AzCRX
Apr 15, 2007 04:23 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
Bontke
Jun 1, 2003 09:51 AM
