Resistor box removal How-To?
Old Nov 26, 2007 | 03:13 AM
killa rex's Avatar
Default Resistor box removal How-To?
I've search to only find a little info.
Car: 91 CRX HF
Motor: D16z6
Obd: Converting completly over to obd1
ECU: P28
Problem: Resistor box
Does anyone have picutres and/or write up of how to eliminate this?
Old Nov 26, 2007 | 04:02 AM
jacoop86's Avatar
Default Re: Resistor box removal How-To? (killa rex)
the risister box is under the hood, driver's side, right next to the firewall. green 5 pin connector. looks like a heatsink sorta.
Old Nov 26, 2007 | 06:05 AM
ludesrv's Avatar
Default Re: Resistor box removal How-To? (jacoop86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacoop86 &raquo;</TD></TR><TR><TD CLASS="quote">the risister box is under the hood, driver's side, right next to the firewall. green 5 pin connector. looks like a heatsink sorta.</TD></TR></TABLE>
Jake, he wants to know how to delete it when going OBD1.
You have to solder all the red wires from the injectors to the red wire going to the resistor box from the ecu. Some people get fancy and pin it to the OBD1 plug which will be yellow/black wires. On the OBD1 harness it's on the passenger side and it will be a plug sorta. It's a plug with an insert in it that connects them all together.
I just soldered and taped mine. Worked fine.
Old Nov 26, 2007 | 06:22 AM
jacoop86's Avatar
Default Re: Resistor box removal How-To? (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
ohh, mabey i shouldnt think when going on 20hr w/o sleep...
Old Nov 26, 2007 | 06:55 AM
ludesrv's Avatar
ohh, mabey i shouldnt think when going on 20hr w/o sleep...</TD></TR></TABLE>
We have all done it lol .
I hope my info was accurate enough. Get confirmation.
Old Nov 26, 2007 | 07:40 AM
jfish360's Avatar
Instead of soldering it i just added a connector, one that has a male and female part and i can disconnect whenever i want to slow car theifs even more.
Old Nov 26, 2007 | 08:05 AM
wickedEFguy's Avatar
Peak and Hold &gt; Saturated Injectors.
why not just use some stock CRX D16 injetors instead of getting rid of the resistor box?
correct me if I'm wrong but I though all d16 injectors were 215's?
dem0nk1d's Avatar
no ****, anything to slow car theft down is two thumbs up!
Old Nov 26, 2007 | 08:44 AM
ludesrv's Avatar
Default Re: (wickedEFguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy &raquo;</TD></TR><TR><TD CLASS="quote">Peak and Hold &gt; Saturated Injectors.
correct me if I'm wrong but I though all d16 injectors were 215's?</TD></TR></TABLE>
All D and B injectors are 240cc.
And if you are running OBD1 ECU you must use OBD1 or OBD2 injectors. Running Saturated injectors on a peak and hold ecu will cause some troubles down the road.
Old Nov 26, 2007 | 12:22 PM
Default Re: (ludesrv)
And if you are running OBD1 ECU you must use OBD1 or OBD2 injectors. Running Saturated injectors on a peak and hold ecu will cause some troubles down the road.</TD></TR></TABLE>
Well OBD0 MPFI are peak and hold so I should have been more specific. OBD1/2 are Saturated. Why would it cause problems to use a peak and hold injector on a OBD1 ECU if you have a resistor box if he they were to use Peak and hold injector from an OBD0 car like a CRX Si/hf or 90-93 Intergra?
makes sense to me because you don't have to re-wire anything and besides Peak and hold injectors are more responsive if he was ever to upgrade.
Go here for more info on saturated/peak and hold injectors.
http://www.msdignition.com/fuel_3.htm
Old Nov 26, 2007 | 01:09 PM
ludesrv's Avatar
I thought the same way as you. I won't bother putting obd1 injectors on my obd1 ecu car. I removed the resistor box (as it will hurt the ecu) and the injectors starting throwing code 16. Eventually I replace them with obd2 injectors and the code went away and vtec finally worked .
Old Nov 26, 2007 | 01:12 PM
BigDare23's Avatar
And if you are running OBD1 ECU you must use OBD1 or OBD2 injectors. Running Saturated injectors on a peak and hold ecu will cause some troubles down the road. </TD></TR></TABLE>
This is new to me??? Never heard such a thing.
Old Nov 26, 2007 | 01:33 PM
Tippyman's Avatar
I thought the same way as you. I won't bother putting obd1 injectors on my obd1 ecu car. I removed the resistor box (as it will hurt the ecu) and the injectors starting throwing code 16. Eventually I replace them with obd2 injectors and the code went away and vtec finally worked .</TD></TR></TABLE>
That's where you went wrong.
Leave the resistor box, and you can keep your peak/hold injectors. They threw a code because they didn't have the resistor box.
Old Nov 26, 2007 | 01:52 PM
I never said to use OBD1 injectors on a car that was converted to OBD1 from OBD0. I was stating that you can use the stock CRX injectors (which are PEAK AND HOLD INJECTORS) on the car so you don't have to remove the resistor box.
A resistor box is needed to run PEAK AND HOLD INJECTORS being how the CRX (Si/Hf) have PEAK AND HOLD INJECTORS you can use them instead of the OBD1 injectors which are saturated and will RUIN the injector driver on the ECU.
So what we learned today is that PEAK AND HOLD INJECTORSrequire a RESISTOR BOX and that on a car that is converted OBD0 -&gt; OBD1 you can use PEAK AND HOLD INJECTORS from a CRX (Si/Hf) since they are PEAK AND HOLD INJECTORS
Old Nov 26, 2007 | 11:32 PM
killa rex's Avatar
Now I'm kinda curious...
If I ran obd1 injectors w/ the resistor box. Will it cause any damage, miss fire, rough idling?
Reason why I asked is because, I'm using my stock HF engine harness, it been cut & soldered with OBD1 injector clips. The car will only start if the resistor box is connected. If not, it will just crank.
Old Nov 27, 2007 | 06:32 AM
Default Re: (killa rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa rex &raquo;</TD></TR><TR><TD CLASS="quote">Now I'm kinda curious...
The reason it won't start is because the injectors aren't getting any power. Yes it will cause damage if you run OBD1 injectors with a resistor box. It'll ruin the injector driver on the ECU.
Old Jun 27, 2019 | 12:40 AM
Weemanink66's Avatar
just wondering can I cut the plug off the resistor box an solder wires together so that if I wona got back to same sorta injectors as factory just bigger ?
Old Jun 29, 2019 | 05:11 PM
DaX's Avatar
DaX
Loved
Community Favorite
Yes, that will work. Make sure you insulate the solder joint well.
88todab16crx
Oct 5, 2008 05:22 PM
Six1oooEG
Dec 14, 2005 02:42 PM
desert eagle
Jul 6, 2004 10:14 AM
fffrog
Feb 3, 2004 04:10 PM
Steve91
Sep 4, 2003 08:22 PM
