FIXABLE OR NOT?!?! help
Old Nov 26, 2007 | 12:14 AM
carlosd68's Avatar
Default FIXABLE OR NOT?!?! help
a buddy of mine hooked me up with a jg manifold , cause im doing an all motor set up but the problem is that its broken from one edge and its missing a hole for a bolt.....i wanna have ur opinions to see if i can still fix this and what suggestions u guys have thanxs in advanve.
Old Nov 26, 2007 | 01:10 AM
Blind-Fashion's Avatar
run it without the bolt, you'll be just fine!
Old Nov 26, 2007 | 03:19 AM
ccarver's Avatar
Run it.
Old Nov 26, 2007 | 01:30 PM
carlosd68's Avatar
i was thinking of just getting them to weld anykind of piece and the ill just drill a hole and see what happens =/
Old Nov 26, 2007 | 02:44 PM
CSaddict's Avatar
Default Re: (carlosd68)
It will not seal without that bolt in. Have it welded and then surface it. Its an easy fix.
Old Nov 26, 2007 | 03:30 PM
civic.slow's Avatar
* B A N N E D *
Default Re: (Mr Wonderfull)
find the broken tab nd but joint it, then machine down the flange so its smooth again
Old Nov 26, 2007 | 03:59 PM
shortyz21's Avatar
Default Re: (civic.slow)
run it.. it wont leak.
Old Nov 26, 2007 | 04:06 PM
m R g S r's Avatar
Default Re: FIXABLE OR NOT?!?! help (carlosd68)
ran too much nitrous and blew the welds off the intake mani? haha
Old Nov 26, 2007 | 05:58 PM
THEDirtyDseriesWOOT's Avatar
lol it prob wont leak , but might as well weld a tab on it drill a hole and suurface it for good measures
Old Nov 26, 2007 | 06:51 PM
Lordofdark176's Avatar
bolt it up and put some silicon gasket maker around it. let it setup for 24 hours, done. no leaks.
Old Nov 26, 2007 | 07:59 PM
carlosd68's Avatar
Default Re: (Lordofdark176)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic.slow &raquo;</TD></TR><TR><TD CLASS="quote">find the broken tab nd but joint it, then machine down the flange so its smooth again </TD></TR></TABLE>
yup ima do that thanx everyone
Old Nov 27, 2007 | 02:26 AM
91jdmhatchback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlosd68 &raquo;</TD></TR><TR><TD CLASS="quote">
yup ima do that thanx everyone</TD></TR></TABLE>
damn for not cheaping out and doing the right thing....
Old Nov 28, 2007 | 05:40 PM
HamiltonRex's Avatar
Default Re: (91jdmhatchback)
its junk.. mail it to me for disposal.
Old Nov 28, 2007 | 05:45 PM
k24em2's Avatar
Default Re: (HamiltonRex)
that'd be a quick fix...i'd rather fix it than run it like that
Old Nov 29, 2007 | 12:19 AM
carlosd68's Avatar
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">that'd be a quick fix...i'd rather fix it than run it like that</TD></TR></TABLE>
yea i am
Old Dec 1, 2007 | 03:14 AM
carlosd68's Avatar
i took it to get it fixed and heres the outcome i think it should be ok now ...just need to drill a hole and maybe cut it a little ........
MakeshiftJPN
May 11, 2012 03:03 AM
305S0L
Mar 2, 2008 01:02 PM
SVOboy
Jul 4, 2006 03:56 PM
lavo81
Suspension & Brakes
Aug 21, 2005 05:47 PM
biotech0123
Welding / Fabrication
10
Mar 27, 2005 09:50 AM
