Switching over to Synthetic?
I have bout 5300 miles on my 08v6 Accord. Should I wait one more oil change to switch over to synthetic, or is there no harm on doing it now. I have about 30 quarts of amsoil 5w-20 id like to start using.
Just a suggestion, after having owned cars/trucks for 30+ years and working on all of them. The next oil change, use a semi-synthetic for 1 oil change, than the following one go to full synthetic.
When I buy a car/truck with a new engine, I change the factory oil to semi-synthetic at about 500 miles, then change the oil to full synthetic at around 1000 miles on the block.
The non/semi synthetics are not as "slippery" and allow the correct amount of seating at the valvetrain and crank bearings- very, very, very slight, but you still need to get some seating. This is also why you do not want to push an engine hard for the first few thousand miles.
I have no doubt kids on this site will argue every knid of angle. I have found many of them can't even do medium-hard repairs, but they sure as hell are experts when it comes to oil!
I have been working on engines for 30+ years, and have built a few in my time. This is what I recommend for a new engine (I know some very well trained mechanics who do the same- semi-synthetic for the firts oil change, then full synthetic after a while). I must admit I know nothong about Amsoil. Wrenchy
Here is from a earlier post on synthetic oil.It might help in your oil choice.
http://www.animegame.com/cars/Oil%20Tests.pdf
Mark
Mark
INteresting article. Too bad it was with Australian brand oils, would be interesting with our off-the-shelf oils and compare the dino-oil, semi-syn and full syn. Maybe take the top two of the cheaper oils and see how they compare to the full gamet of full-syn available: Mobil 1, Redline, Royal Purple, Amsoil, etc.
Anyway: I concur with Wrenchy. Myself also having 25 years of playing around with cars and several cars that have had synthetic run in them since near new, a synthetic engine is MUCH MUCH cleaner than a dino oil engine after 100k+ miles. THis is point one of why I use full synthetic.
Point 2: Major performance cars come from the factory with synthetic and run extended intervals: Corvettes, BMW's (12.5k mile just filter and oil & filter at 25k intervals), Cadillac, etc. Virtually any SCCA club racer you can find will race only with synthetic.
Point 3: Actually can cost LESS short term too. USe synthetic and a good filter and, if under warranty, stay with the standard oil recommendation of 7500 miles. This equates to 2 changes in 15k miles or about $60 ($6/quart, 8 quarts total, $6 filter). Using regular oil and the needed 3k mile changes, 5 changes in 15k miles equals $80 ($2.50/quart, $6 filter, $16 per change). If you take it someplace, the cost savings is even higher due to the labor cost at each change.
Point 4: Not sure which of the synthetics is THE BEST but from the report mentioned above, Royal Purple looks pretty good and is a racer's choice oil. Not sure how Amsoil compares but they due GUARANTEE 100% synthetic oil. Due to a legal battle that Castrol won, oil companies only need to have 1% of the base stock as man-made or man-modified to claim the oil as 100% synthetic. This could explain in the test report why some "semi" synthetics outperformed their "FULL" synthetic brother oils. As for semi sythetic, the same 1% legal ruling applies - only 1% of the oil has to be "FULL" synthetic, the rest can be regular oil. If this is true, then you would be better off mixing YOUR OWN SEMI-SYNTHETIC. Buy some Royal Purple and mix it with a good brand of regular oil. This may be the best bet as Wrenchy explained above: start with a 25/75 mix of syn/regular oil for an oil change, then go to 50/50 for another, and then a 75/25 for one more and then you will be up to a 100% synthetic oil.
I've switched to PP back in August on my 1995 Accord. I've experienced somewhat of a leak, and after researching, some say that it should go away after awhile due to the deposits building back up.
Can anyone give any insight?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">leaks just don't go away, you gotta FIX THEM. looks like you need some new seals</TD></TR></TABLE>
Well dammit.
Everytime I have a leak and fix it, somehow it seems to always come back.
Well dammit.
lamboextreme
88
Mar 6, 2007 07:34 PM
FifthGearOnline
Jan 2, 2002 10:33 AM
