stainless brake line/new caliper question....
Old Nov 25, 2007 | 08:02 PM
beav's Avatar
Default stainless brake line/new caliper question....
hey guys...
i have a 98 civic with stainless steel brake lines.
i need to change a caliper, and i know with rubber lines, you can just squeeze them shut with a vice grip of something, so you wont have to re-bleed all the brakes.
i want to know if this is possible to do wth steel lines. and if it is, will there be any sort of drawbacks. i do not want to damage my lines, im just uncertain of the flexibility of these lines.
Old Nov 25, 2007 | 09:56 PM
beav's Avatar
Default Re: stainless brake line/new caliper question.... (beav)
bump...someones gotta know.
Old Nov 26, 2007 | 06:05 AM
1991civicsi's Avatar
I would bleed them whenever a line was opened.
Old Nov 26, 2007 | 07:42 AM
hatchling37's Avatar
That sucks. I don't think it's possible to put a line lock or similar device on a stainless line without damaging it. That's its whole purpose- not to flex. I would just be prepared to quickly swap everything over once you crack that line loose. I know that sounds like a pain, but it might be your only option. You might try to run a small hose up to the reservoir from the bleeder, but I would avoid opening the
reservoir whenever possible.
Man, I hadn't ever thought about that kind of problem.
Old Nov 26, 2007 | 09:28 AM
alscrx's Avatar
Default Re: stainless brake line/new caliper question.... (hatchling37)
You should only have to bleed that one side
justinball1717
Honda Civic (2001 - 2005)
Oct 24, 2016 06:43 PM
94CivicSi
18
Mar 28, 2008 05:03 AM
JCracer723
Mar 9, 2007 06:52 AM
jolt-tsp
20
Sep 2, 2003 10:10 AM
turbospool
Aug 10, 2003 11:38 AM
