? For my GSR good idea or bad?
Old Nov 25, 2007 | 07:55 PM
kenoshaGSR's Avatar
Default ? For my GSR good idea or bad?
Ok so im new to this site and need some help
I have a DA 92' GSR i wanna build the motor w/ springs,valves,cams,camgears,etc.
but worried about it cause i have 174000 miles on it
should i go for it or am i askin for trouble?
need some inputs
thanks
Old Nov 25, 2007 | 07:58 PM
all-mtr-teg's Avatar
Default Re: ? For my GSR good idea or bad? (kenoshaGSR)
Do a compression test and see how your bottom end is, if test shows signs of worn rings, do a complete bottom end rebuild if you can afford it. New rings and bearings aren't that much if you pull the motor yourself and just have a shop hone the block and assemble the bottom end.
Old Nov 25, 2007 | 08:04 PM
allmotorteg02's Avatar
all-mtr-teg is right you should def be fine just have the shop do a compression test and they will tell u wether or not ur good to just do a rebuild or if u need more or the block is no good u can also have them test it for any signs of stress cracks or anythign. as long as u go to a good machine shop you will be fine.
Old Nov 25, 2007 | 08:05 PM
jordanitr's Avatar
Default Re: ? For my GSR good idea or bad? (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression test and see how your bottom end is, if test shows signs of worn rings, do a complete bottom end rebuild if you can afford it. New rings and bearings aren't that much if you pull the motor yourself and just have a shop hone the block and assemble the bottom end.</TD></TR></TABLE>
What he said
Old Nov 25, 2007 | 08:11 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: ? For my GSR good idea or bad? (jordanitr)
Don't take it to a shop. I live 20 minutes away, and will do a compression test for a six pack of Rolling Rock. And yes, I have done it on a DA
Old Nov 25, 2007 | 08:29 PM
always smooth's Avatar
Default Re: ? For my GSR good idea or bad? (Uncle Ben's)
nice, kenosha (my hometown). good to see fellow wisconsin owners helpin eachother out
Old Nov 25, 2007 | 08:35 PM
db1_jdm's Avatar
Default Re: ? For my GSR good idea or bad? (always smooth)
yeah do compression checks urself, not hard at all.
Old Nov 26, 2007 | 06:34 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by always smooth &raquo;</TD></TR><TR><TD CLASS="quote">nice, kenosha (my hometown). good to see fellow wisconsin owners helpin eachother out</TD></TR></TABLE>
kenosha sucks (another fairly local member here)
Old Nov 26, 2007 | 06:40 AM
St Jimmy's Avatar
* B A N N E D *
Before spending 1000+ dollars on cams, valvetrain, etc I would do some research its really not worth the money unless you plan on building other parts of the motor for an all motor setup which in the long run is very costly. Look into turboing your car, it can produce alot biger HP numbers than cams and still be a reliable daily driver for the fraction of the cost of a all motor setup.
And compression test is a must for a car with that many miles before doing any serious mods.
Old Nov 26, 2007 | 09:10 AM
Default Re: ? For my GSR good idea or bad? (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">kenosha sucks (another fairly local member here)</TD></TR></TABLE>
It's not as bad as Racine
Old Nov 26, 2007 | 09:16 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Ben’s &raquo;</TD></TR><TR><TD CLASS="quote">
It's not as bad as Racine </TD></TR></TABLE>
agreed
i grew up in franklin now live in muskego
racine is ghetto as hell now though
Old Nov 26, 2007 | 04:14 PM
kenoshaGSR's Avatar
i like how this thread turned into a were i live haha
but yeah uncle bens i got the beer if we can do some work
Old Nov 26, 2007 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenoshaGSR &raquo;</TD></TR><TR><TD CLASS="quote">i like how this thread turned into a were i live haha
but yeah uncle bens i got the beer if we can do some work</TD></TR></TABLE>
You have PM
Old Nov 26, 2007 | 07:47 PM
i like kenosha
Old Nov 26, 2007 | 07:59 PM
CB's Avatar
CB
Brookfield Maybe take you're head to King for some head preperation if the compression test blows.
Old Dec 1, 2007 | 11:29 PM
guygeneric's Avatar
bump for 92-93 GSRs, a fine vehicle to own, what color by the way?
Old Dec 4, 2007 | 10:07 AM
super china china's Avatar
x2
Old Dec 4, 2007 | 10:35 AM
19ex96's Avatar
rebuild it while your at it
DCM
Apr 4, 2011 05:23 AM
mynameizstitch
May 21, 2009 10:13 AM
RussHondaCRX
Jan 24, 2005 10:16 AM
DxTrix
Aug 15, 2003 04:58 PM
