Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
what is worse?
Old Nov 25, 2007 | 05:18 PM
Mechman456's Avatar
Default what is worse?
Which is worse and puts more strain on the motor???
1. During acceleration rev the car a little higher only half throttle?
2. Or keeping it in higher gears and have the peddle to the floor keeping the tach in the low rpm range???
Old Nov 25, 2007 | 07:15 PM
mr. biggles's Avatar
Default Re: what is worse? (Mechman456)
whatttttt
Old Nov 25, 2007 | 07:23 PM
SMoLiK9's Avatar
* B A N N E D *
If the motor sounds like it is straining to make power... Shift to a lower gear... Chances are if your flooring it to move at a steady pace, your causing the engine too much stress... Cars talk, you just have to listen...
SMo'
Old Nov 25, 2007 | 08:43 PM
zid's Avatar
zid
Default Re: (SMoLiK9)
are you talking about going up a hill? if you have to floor it to keep going then you need to downshift. the engine is designed to be above 2k, its better to be on the gas less
jr408
Feb 27, 2008 11:50 AM
Honda.F1
Honda Civic (2001 - 2005)
Apr 30, 2007 02:31 PM
hondadriver
Mar 10, 2006 12:51 PM
mikeyp5d
Oct 28, 2005 01:52 PM
spinny
Jan 25, 2005 02:45 PM
