mini me problems
Old Jun 25, 2002 | 08:03 AM
slowstang's Avatar
Default mini me problems
before the swap my car ran a 15.7 on the stock motor w/ intake, exaust and adj fpr. we did the swap and it runs in the 16's now. wtf went wrong? somtimes it shuts off after i drive it fora little bit, rpms somtimes drop. i have a 88 d16a6 block w/ a 93 d16z6 head. i used a summit rpm activated switch to activate vtec, i have a light and i thave it set right, but im not sure its really engaging. i used the crx intake manifold and a pacesetter header for the d16a6. also have a adj cam gear, but we tuned it to perfection. its set at the 6 mark, so 12* of timing...that seemed to work the best. fuel pressure is at 48. its got good low end torque, i could feel the difference, but there is NOO power top end, what could cause this!!!
thanks
chris
Old Jun 25, 2002 | 08:36 AM
88_SC_CRX_Si's Avatar
New User
Default Re: mini me problems (slowstang)
It sounds like your still not getting VTEC. I switched/flipped all the dip switchs over in my Sumitt yada yada, and then I heard a cluncking/clicking sound. I took that to be the switch activating... Might try that on yours, and see if you hear anything.
Probably already heard this, but without the P28 ECU and it's timming maps, more soooo then the fuel. It does hurt overall performance... hehehe
Just a thought...
Old Jun 25, 2002 | 09:24 AM
builthatch's Avatar
MiG-21 superfan
is that rpm switch the kind that provides a ground at the desired rpm? my msd rpm switch provides a ground for a 12v relay, in turn, the relay is now powered and sends 12v to the soleniod....what you should do is splice a 12v lite temporarily into the vtec soleniod wire put it under you windshield wiper so you can see it from the cockpit and drive- JUST to see if the soleniod is getting power @ the desired rpm. with one terminal grounded and the other connected to the soleniod, it should lite up when you hit the rpm you have the rpm switch set to...
Old Jun 25, 2002 | 09:48 AM
slowstang's Avatar
Default Re: mini me problems (builthatch)
yeah we have it going through a 12v relay, its the same setup as yours im guessing. my battery died, the damn thing wont even start now lol...damn this honda...i have a light on my dash tapped to the wire goin to the vtec solenoid...i dont know what else to do now...your in ocean city? thats only about an hour from me. i live near medford/marlton area.
thanks
chris
Old Jun 25, 2002 | 09:55 AM
builthatch's Avatar
MiG-21 superfan
hahaha...damn the honda!...well charge her up and let us know if the lite turns on @ vtec ...................... marlton? i love pf changs in the promenade, my girlfriend and i go there weekly for dinner...
[Modified by builthatch, 1:56 PM 6/25/2002]
Old Jun 25, 2002 | 11:13 AM
ryu12341's Avatar
PF Changs is GOOOOOODD...
Old Jun 27, 2002 | 06:35 AM
slowstang's Avatar
Default Re: mini me problems (ryu12341)
i stil havent had any luck w/ thing, i went by pf changs yesterday but we ate at salad works..my friend works there so we got hooked up ..anyway...im gona give up on this thing...
later
chris
Old Jun 27, 2002 | 06:53 AM
speedillusion's Avatar
New User
it might be too late...
go to ezboard. check this d series forum out. they can help.
http://pub34.ezboard.com/bhondadseries
slowstang's Avatar
built hatch, you wanna run somtime? ill run ya in the rustang lol...once i get my driveshaft...maybe we could meet up somtime...when you headin to atco? later
chris
Old Jun 28, 2002 | 02:09 AM
kinesistech's Avatar
I have the answer you seek, but you aint gonna like it.
The 92-95 sohc vtec heads have the cam cut 20 degrees different than 88-91 or 96-01. The slot for your distibutor is where the problem lies. It is what is about 20 dgrees off. Tune your cam gear like 13 degrees and it'll improve your cam timing but make your ignition timing ****. You need at least a cam from a 96-up vtec. That will enable you to get the cam timing AND the ignition timing both right at the same time. The 92-95 heads have different rocker arm geometery though so it will either offerm ore or less lift and duration than its supposed too.
Have fun. Look at the bright side. You met someone who already knows.
Old Jun 28, 2002 | 05:05 AM
95hbMatt's Avatar
Default Re: mini me problems (kinesistech)
you might have went through this how-to already but just in case here it is so you can go through it...z6 head onto a 89-91 crx:
http://crx.honda-perf.org/articles/z6swap/z6swap.html
outtacontrolsol
Jul 10, 2011 10:13 PM
LupeSI
13
Jul 19, 2008 04:39 PM
Magnum000
Feb 19, 2004 09:48 AM
slowstang
Jun 25, 2002 10:25 AM
max
Aug 7, 2001 09:00 PM
