rev limit at 7700 w/b16a w/gsr cluster
Old Nov 24, 2007 | 09:20 AM
90B16aCRXsi's Avatar
Default rev limit at 7700 w/b16a w/gsr cluster
hi i have a 90 civic with a sir b16a swap. The other day i installed a gsr gauge cluster and ever since then my rev limit is 7700. I have a proform shift light set a 8000 and its always been right on now the car hits at 7700 and the light does not come on and feels like i have no power. I have an msd 6 series box msd pro cap and external coil. I dont know whats going on any help would be much appriciated. thank you
Brian
Old Nov 24, 2007 | 12:57 PM
JakeSpec's Avatar
Default Re: rev limit at 7700 w/b16a w/gsr cluster (90B16aCRXsi)
is your speedo working? check engine 17? maybe its not cracking V, and if your ecu is stock the check likght wont let it rev past 7500
Old Nov 24, 2007 | 12:58 PM
JakeSpec's Avatar
Default Re: rev limit at 7700 w/b16a w/gsr cluster (JakeSpec)
you need to wire up an electric speedo from the cluster to the comp to the speedo! look on hybridgarage.com for the wiring diagram
Old Nov 24, 2007 | 03:06 PM
Yeah ive got the orange wire from the electric speedo to the sixth pin on the back of the cluster like it says to do but ill check that site. thank you
Old Nov 24, 2007 | 03:07 PM
yeah i do have the number 17 code comin up on my pw0 i think that is vss right? Yes my speedo is working
Old Nov 24, 2007 | 03:14 PM
that site just takes me to a search engine for hybrid cars and trucks
Old Nov 24, 2007 | 05:43 PM
hey thanks for all the help i got it fixed. i had to run that jumper wire to the ecu. Now the temp gauge doesnt work haha. Thanks again.
Old Dec 2, 2007 | 06:10 PM
JakeSpec's Avatar
check the single wire prong SENSOR on the side of the head most of the time its just the dumb sensor! ITS A 12MM DEEP SOCKET TO TAKE IT OUT
Old Dec 2, 2007 | 07:38 PM
Your sayin just replace it with a new one.
Old Dec 3, 2007 | 07:50 AM
JakeSpec's Avatar
yup
rmrider12522
Sep 16, 2013 10:13 AM
Lazysk8r2
Feb 19, 2012 06:51 AM
fiji_crx
Jul 31, 2007 12:22 AM
ham
16
Aug 21, 2004 10:26 AM
