y7 head on z6 block?
Old Nov 23, 2007 | 05:20 PM
ZCcivicBOI's Avatar
Default y7 head on z6 block?
i searched and i was wondering if it was possible to put y7 head on z6 block i know the timing belt will work and stuff but what about the oil since its non vtec head on vtec block any info would help thanks..
Old Nov 24, 2007 | 10:23 AM
jlicrx's Avatar
Default Re: y7 head on z6 block? (ZCcivicBOI)
you would need to put the oil restrictor in the top of the block - other than that, the head will work - the Z6 distributor will not bolt onto the Y7 head
Old Nov 24, 2007 | 10:30 AM
SIred91's Avatar
Rainman
Default Re: y7 head on z6 block? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">you would need to put the oil restrictor in the top of the block - other than that, the head will work - the Z6 distributor will not bolt onto the Y7 head</TD></TR></TABLE>
You need 101% man.....lol.....
Old Nov 24, 2007 | 11:39 AM
Dr. D-Series's Avatar
Dont give out wrong info.
No oil restrictor is needed.
Put the head on.
BTW I have a z6 block with y7 head running in my hatch.
Old Nov 24, 2007 | 05:41 PM
ZCcivicBOI's Avatar
Default Re: (Dr. D-Series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">Dont give out wrong info.
Put the head on.
BTW I have a z6 block with y7 head running in my hatch.</TD></TR></TABLE>
thanks, so i can just bolt it on and i looked up the part # for the y7 timing belt and its the same as a z6 so i should be able to use my z6 timing belt and everything?
also i see in ur sig ur running boost is that on the z6 block y7 head setup? if so does it run pretty well?
thanks for all the info
Old Nov 24, 2007 | 06:14 PM
z6 belt will work just fine. Same belt.
z6 block y7 head just went into the car last week. It is boosted, just not tuned yet.
Pulled the d15 block for the current built z6 block.
Good luck with it.
Old Nov 24, 2007 | 08:06 PM
ZCcivicBOI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">z6 belt will work just fine. Same belt.
Good luck with it.</TD></TR></TABLE>
alright thanks for the help imma slap the head on tomarrow and see how it goes.
Old Nov 24, 2007 | 09:03 PM
mr.speaker's Avatar
Default Re: (ZCcivicBOI)
Put the head on.
I dont understand..The D16z6 block doesnt have an oil jet because its in the d16z6 head..And the Y7 head doesnt have the oil jet in the head,,So you have a motor with no oil jet and say it runs fine? I don't understand
Old Nov 24, 2007 | 09:30 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: (mr.speaker)
X2
I'm not doubting either way, but if you run without it, what's the point of having it in the first place?
Old Nov 25, 2007 | 04:34 AM
What oil jet are you talking about ?
88-95 d15bX's had an oil orific on the deck of the block. You need to remove that to run a vtec head. This doesnt apply here.
And anyway, I ran a d15 block with y7 head for about 4 years with no orific.
What the expletive is all the confusion about ?
Old Nov 25, 2007 | 04:51 AM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">What oil jet are you talking about ?
What the expletive is all the confusion about ?</TD></TR></TABLE>
you're the confusion..you ran a D15 block!!
THE D16Z6 BLOCK DOESNT HAVE AN OIL JET IN THE BLOCK,IT HAS IT IN THE HEAD AND THE Y7 HEAD DOESN'T HAVE A OIL JET IN IT LIKE THE VTEC HEAD,,SO A Z6 BLOCK AND Y7 HEAD COMBO MEANS YOU DON'T HAVE AN OIL JET unless you add one.
Old Nov 25, 2007 | 05:14 AM
Correction. I ran 12.1 on a stock d15 block.
What the hell do you need the oil jet for is what I cant understand !
Old Nov 25, 2007 | 05:24 AM
ZCcivicBOI's Avatar
yes im running the d16z6 block with d16y7 head so since my head and my block dont have a oil jet i need to add one into my block?
i have heard that no oil jet will cause to much oil to go to the head and not enough stays in the block which makes it spin rod berings..
i just need to know if i need to add oil jet lol.
Old Nov 25, 2007 | 05:25 AM
ZCcivicBOI's Avatar
I also just read that a y7 block has an open oil passage just like the y8/z6 block so does that mean the oil jet is in the head like the z6/y8 heads?
Old Nov 26, 2007 | 04:49 AM
ZCcivicBOI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCcivicBOI &raquo;</TD></TR><TR><TD CLASS="quote">I also just read that a y7 block has an open oil passage just like the y8/z6 block so does that mean the oil jet is in the head like the z6/y8 heads?</TD></TR></TABLE>
anyone know?
Old Nov 26, 2007 | 07:01 AM
ludesrv's Avatar
I would also use a Y7 head gasket, just incase there are any oil passages that need blocking, better to do it with the gasket then the head IMO.
dc101
Apr 8, 2011 12:42 PM
_EF9
Jun 19, 2008 05:29 PM
ZCcivicBOI
Nov 23, 2007 06:41 PM
trbodelasol
Apr 2, 2005 07:48 PM
