Suspension & Brakes Theory, alignment, spring rates....
Alignment....
Old Nov 23, 2007 | 12:40 PM
924doorEG's Avatar
Default Alignment....
I have a 92 civic 4 door lowered 4 inches on HX wheels, and i noticed my car loves to pull to the right side, and the rear wheels and tires look kinda slanted like it has positive camber, and the inside of the front tires have wear. i want to get an alignment, so what are the specs you guys suggest?
Old Nov 23, 2007 | 01:06 PM
PIC Performance's Avatar
Default Re: Alignment.... (924doorEG)
0 for the toe all around. If you have POSITIVE camber on a car that's lowered 4 inches (which is way too low, btw), then something is bent. Find out what's bent, fix it, then align it. You should have negative camber on a lowered Civic, not positive.
Old Nov 23, 2007 | 01:09 PM
924doorEG's Avatar
well idk for sure if its positive camber, how do you know for sure? im just guessing by what i hear
Old Nov 23, 2007 | 01:19 PM
924doorEG's Avatar
Default Re: (924doorEG)
can anyone look and tell me what they think if somethings bent?
Old Nov 23, 2007 | 02:48 PM
924doorEG's Avatar
bump help plse
Old Nov 23, 2007 | 03:23 PM
Targa250R's Avatar
be professional
Can't tell via those pictures, and realistically, it's hard to tell at all without looking at the car in person. It looks normal for a '92-95 Civic to me from here.
Your best bet is to get the car on an alignment rack. Have them set the toe to dead center of the factory specs at all four corners, and make sure you ask for both the before and after print-outs.
Post the results of the alignment here.
Old Nov 23, 2007 | 09:28 PM
shadohconspiracy's Avatar
that doesnt look like a 4 inch drop and your camber looks normal...
my car pulls to the right under acceleration , thats because i have uneven negative camber and theres really nothing i can do about it unless i get a camber kit
Old Nov 23, 2007 | 10:08 PM
924doorEG's Avatar
ahh thats the same thing mine dose
Exia
Suspension & Brakes
Feb 11, 2013 05:00 PM
madmixer
10
Jun 24, 2007 08:51 AM
alex_s817
Apr 17, 2006 07:51 PM
Ludeboi
Apr 25, 2003 11:26 PM
WheAs MaI MojO
Oct 11, 2002 08:06 PM
