JUN 3 cam gear degreed???
Hi guys,
Im going back to the dyno with my new 82mm set-up...everything else is the same into my set-up exept ive change my OEM ITR TB to a port match 68mm skunk2 TB thats it...same CR same header etc...
The 81.5mm set-up put down 215whp/135wtq on a mystang dyno with the cam gear not degreed and set at 0/0!!!
I wanna ask the tuner to play with them and ive heard that when you find the rigth setting with the gears...those cams can produce lot more power that they were making into my first set-up!!!
So im calling out all JDM ITR engine owners with JUN 3 cams
Thanks
Mike
Thanks
Mike
canuck-mx6
Aug 8, 2002 08:26 AM
SIINSI
27
Jan 13, 2002 09:15 PM
