Got weird engine problem
Old Nov 22, 2007 | 09:21 PM
rotascircuit's Avatar
Default Got weird engine problem
Hey I got a 95 honda civic si with a 95 gsr engine. When I go lets say start with first gear then second and then like fourth and floor it then the car like jerks like tooo much gas is going in the engine and not enough rpm. so basically when I am on low low rpm and floor it the car like jerks or like not shakes but its hard to explain Is that normal or something wrong got 107k in the engine
Old Nov 22, 2007 | 09:36 PM
ejoner's Avatar
Default Re: Got weird engine problem (rotascircuit)
Throwing any codes? Does it jerk if your in any other gear and floor it? Have you checked your motor mounts?
Old Nov 22, 2007 | 09:38 PM
prettylew's Avatar
do you have an adjustable fuel pressure regulator? maybe your pressure is too high
Old Nov 22, 2007 | 09:48 PM
ejoner's Avatar
Default Re: (prettylew)
If the fp was set too high it wouldn't only happen in 4th.
Old Nov 23, 2007 | 02:03 PM
Default Re: Got weird engine problem (ejoner)
well you know.... I dont have any code and yes it does happen in every gear Or could it be something do with the exhaust system because I still have the 1.5 or 1.6 stock 95si exhaust so.............
Old Nov 23, 2007 | 02:35 PM
raphael's Avatar
well if your in 4thgear at around 1.5k rpm the motor will not have enough torque to immediately pull you in yor seat instead it will jerk and sputter until it reaches max torque and horsepower.
Old Nov 23, 2007 | 02:37 PM
Default Re: (raphael)
so is that normal?????
Old Nov 23, 2007 | 02:47 PM
platinumx6's Avatar
when your in to high of a gear the car will shutter.
the shaved trim doesnt look bad on your car. atleast you kept the handles
Old Nov 23, 2007 | 02:58 PM
vtec25's Avatar
i think you have to explain your symtpoms just a smidgen better, its hard enough to diagnose problems over a computer.. and perhaps invest in hooked on phoenics
Old Nov 23, 2007 | 08:05 PM
rleonekc's Avatar
Default Re: (vtec25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinumx6 &raquo;</TD></TR><TR><TD CLASS="quote">when your in to high of a gear the car will shutter.
the shaved trim doesnt look bad on your car. atleast you kept the handles </TD></TR></TABLE>
Its normal! If your in too high of a gear, yeah, your cars gonna feel like it wants to die
Old Nov 23, 2007 | 08:32 PM
civiconfire's Avatar
your ignition timing could be off a little. my car was doing that when i first put my motor in. but i had the wrong distributer anyways. have someone put a timing light on it
rotascircuit
11
Dec 8, 2007 11:10 PM
rotascircuit
21
Dec 7, 2007 11:13 PM
rotascircuit
Dec 7, 2007 05:22 PM
JDMoMo
Jun 12, 2005 06:09 AM
