What do you guys think of my brake setup? (OE stuff)
I drive a 96 Civic EX and all four corners are worn, trailing arm bushing is finished, ebrake cable is seized. I picked up SiR full suspension/brakes for $300. Am paying $200 for labour since I heard its not that easy especially since its winter time.
Front: Brembo Blanks w/ Hawk HPS (Damn they rape us for Brembo in Canada... paid 110 for the rotors and 65 for the pads).
Rear: Si trailing arms w/ Brembo Blanks w/ PBR Semi-Metallic [aka Metal Masters] (The store couldn't get the HPS pads in stock by this weekend which is the appointment I have with my mechanic).
What do you guys think of the Hawk HPS front and PBR MM rear? Bad mix or what? I really wanted a matching set but I am an impatient expletive. Should I try to go for PBR Ultimates, Hawk HPS rears, or just keep them since the rears are hardly used.
P.S. Tokico Blue Shocks are ******* garbage and its true... do it once or spend twice as much to do it right. I am lowered on H&R Sport if that matters. I am so tempted to ditch the rear (still using Honda front shocks because they are holding up) and switch to Koni Reds).
I am going to follow these instructions
Burnishing Instructions
1. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
2. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
3. DO NOT DRAG BRAKES!
4. Allow 15 minutes for brake system to cool down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawlin »</TD></TR><TR><TD CLASS="quote">are you going to switch out the master cylinder? makes a bit of a difference.</TD></TR></TABLE>
I agree, get a 15/16" mc off of a 1989 ex wagon. Autozone sells them.
Modified by ek forever guy at 9:20 PM 11/22/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
I agree, get a 1" mc off of a 1989 ex wagon. Autozone sells them.</TD></TR></TABLE>
i think ur talkin about the 15/16" mc for the civic ex wagon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">I agree, get a 1" mc off of a 1989 ex wagon. Autozone sells them.</TD></TR></TABLE>
only 1" master is the integra type-r
15/16" from the 1988 civic SEDAN EX not wagon.......and that only works on NON ABS honda civics
you can go integra but you need the booster too
square_1
Mar 25, 2010 04:37 PM
slvrcivic97
39
May 22, 2003 09:03 PM
neveronlines2k
15
Apr 19, 2002 10:34 PM
