trailing arm??
Old Nov 22, 2007 | 05:25 PM
shaun_john's Avatar
Default trailing arm??
I need to replace my left rear trailing arm on my 91 hatch, would one off a 93 civic fit it?
Old Nov 22, 2007 | 06:11 PM
shaun_john's Avatar
Default Re: trailing arm?? (shaun_john)
anyone know???
Old Nov 22, 2007 | 07:05 PM
coot_er's Avatar
i think it is slightly different but will work. if i remember right it will make your tire go out by just a little.
Old Nov 23, 2007 | 01:40 AM
LerRoy1119's Avatar
Default Re: trailing arm?? (coot_er)
to my understanding all 88-00 civic and 90-01 integra trailing arms is the sam only difference is drum or disc
Old Nov 23, 2007 | 03:54 AM
alscrx's Avatar
Default Re: trailing arm?? (LerRoy1119)
DO you have rear disc or drum??
You should try to use a crx one, But if you can't find grab and integra one!
Old Nov 23, 2007 | 07:15 AM
shaun_john's Avatar
Default Re: trailing arm?? (alscrx)
I found one from a friend for 40 bucks...would a 93 still fit it cause i have one laying around.
Old Nov 23, 2007 | 07:21 AM
coot_er's Avatar
it will definatly fit. you just have to becareful if you ever change out your trailing arm bushing, i think they are different sizes however you can get the crx one to work.
Old Nov 23, 2007 | 09:09 AM
ludesrv's Avatar
IT will bolt up.
89-91 civic/crx trailing arms are what you should use. All other teg and civic trailing arms will make the wheel buldge out a little. I think about 12mm per side or something like that. The mounting points are the same just keep your stock control arms.
shahriar35
Apr 21, 2016 03:19 PM
pablopab50
Suspension & Brakes
Aug 21, 2013 08:47 PM
drew2
13
Jul 27, 2006 07:50 AM
ED9man
21
Jun 7, 2006 05:07 PM
Another Drew
Sep 1, 2004 06:03 AM
