NEED HELP WITH MINI ME ASAP
so i got a d15b8 and i m about to put my y8 head on and i look at the head bolts and my far left last bolt sits higher than the rest. so i compair the heads and the b8 head is higher on just the last bolt unlike the y8. wat do i do wont the bolt not tightin down
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y_my_91 »</TD></TR><TR><TD CLASS="quote">so i got a d15b8 and i m about to put my y8 head on and i look at the head bolts and my far left last bolt sits higher than the rest. so i compair the heads and the b8 head is higher on just the last bolt unlike the y8. wat do i do wont the bolt not tightin down</TD></TR></TABLE>
you gotta use the original D15 headbolt in that one spot. hope you kept it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y_my_91 »</TD></TR><TR><TD CLASS="quote">i did but looks as if the thread itselfs sits higher or some ****</TD></TR></TABLE>
if it does not work then you got the wrong bolt, you need the exact bolt that goes in the D15 head and block in that exact spot and IT WILL WORK, if not your doing something wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Or get head studs...</TD></TR></TABLE>
if he wants to spend more money, yes. I say just use the OEM stud and call it a day as long as your not boosting it you'll be just fine
i just checked all the head bolts they are all the same. if you throw the bolts in and not even screw them in that bolt sits higher. then i put the stock head back on and its fine. i ll post some pictures up. if anyone has a mini me please do me a big *** favor and pull the valve cover off and check
well i think i got it figured out if you use a z6 head it will be fine because the b8 and z6 have the same design but if you use a y8 head you need a stud for that last bolt or cut that bolt and i tested that to and you can tightin down to stock torqe specs with out stripin the thread.
i have a stock a6 block with the z6 head...no problems. i personally did my research before choosing b/t the z6 and y8. from what i found out, you want the z6 head with the y8 intake manifold. just a little fyi. not that the y8 head won't do you good, it's just that bench-flow tests show better results with port/polish and valve job on the z6 head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome »</TD></TR><TR><TD CLASS="quote">
if it does not work then you got the wrong bolt, you need the exact bolt that goes in the D15 head and block in that exact spot and IT WILL WORK, if not your doing something wrong</TD></TR></TABLE>
Incorrect, it's actually the opposite when you use the D16Y8 head on a D-Series 88-95 block. For that one bolt in the upper left corner, you need a head bolt for the D16Y8 head. It's in the FAQ.
zach53
Jun 17, 2012 10:06 AM
dj_zyx
Jul 13, 2007 04:51 PM
