BOOST
Old Nov 21, 2007 | 11:05 AM
hondajav06's Avatar
Default BOOST
I.m trying to build a race motor for street use but
don''t know whether to usea lsvtech or gsr or type r motor I have an
idea
of what type of pistons to use but I''m stuck on what type of motor
will
be best for 25 to 30 ilbs of boost any ideas
Old Nov 21, 2007 | 11:08 AM
Syndacate's Avatar
Default Re: BOOST (hondajav06)
Learn what the hell you're talking about, then come up with an idea.
25-30psi out of any turbo is massive for a street build.
Maybe I'm missing something but judging by the way you worded that I'ma say you're not skilled enough to change the oil in your car, none-the-less do all that bullshit you just mentioned.
PS: It's VTEC, not vtech.
Use Vitara pistons.
Use a GSR.
Old Nov 21, 2007 | 11:09 AM
TorganFM.'s Avatar
Sohc + Vitaras + TT/Eagle rods + arp studs. Under a grand and you're good for 400 or more.
Old Nov 21, 2007 | 11:11 AM
Syndacate's Avatar
Default Re: BOOST (TorganFM.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TorganFM. &raquo;</TD></TR><TR><TD CLASS="quote">Sohc + Vitaras + TT/Eagle rods + arp studs. Under a grand and you're good for 400 or more.</TD></TR></TABLE>
There were no SOHC's on his engine dream list .
Old Nov 21, 2007 | 11:15 AM
hondajav06's Avatar
Default Re: BOOST (Syndacate)
Is there a reason y i should get a GSR and not a Type r??? I am not new to this kinda stuff i am just new to turbos and i was just exagerating when i meant 25-30 i want something safe and reliable
Old Nov 21, 2007 | 11:17 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajav06 &raquo;</TD></TR><TR><TD CLASS="quote">is there a reason y i should get a gsr and not a type r???</TD></TR></TABLE>
If you're building a race motor you'll have to pull the compression ratio on the ITR to pull sufficient boost or you'll need to run race fuel. Since you're going over 300hp you'll need forged internals anyways, so what's the sense in buying a motor that's made for high compression all motor HP if you're just taking the pistons/rods out and replacing them with aftermarket ones in prep for boost?
Old Nov 21, 2007 | 11:23 AM
hondajav06's Avatar
Modified by hondajav06 at 12:52 PM 11/21/2007
Slotz_HB
Jul 6, 2010 12:04 AM
killablaze
Mar 29, 2010 10:09 PM
fusion645
Jan 2, 2010 05:47 AM
n17r0us
Oct 13, 2009 04:51 PM
v1nyd
Dec 8, 2007 10:45 PM
