how to hook up a shift light.? (not a diy)
Old Nov 21, 2007 | 08:17 AM
tyler100's Avatar
Default how to hook up a shift light.? (not a diy)
I was wondering if anybody would know how to hook up a shift light to a stock tach?
I have searched and haven't found anything. I found one post but it diddnt really tell how to do it. I got the shift light off a junk ebay tach that i got and the tach was fried and i don't want a gaudy tach on my dash. so i was thinking i could just wire up the shift light off of it.
oh and its a 88 crx si if that helps any.
-TYLER
Old Nov 21, 2007 | 08:45 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: how to hook up a shift light.? (tyler100)
find what i believe is the blue with a white tracer wire out of the back of the tach side of your cluster harness, T off of that, give it a switched power and ground ( so the thing doesn't have power all the time ) and you should be ready to rock and roll. IMO its THE most annoying mod you can do unless its one of the LED ones where you can dim it or turn it off. Bright lights in your face at night is no good.
Old Nov 21, 2007 | 08:47 AM
tyler100's Avatar
thanks, wont it only flash at redline?
Old Nov 21, 2007 | 09:45 AM
ComeOnKip's Avatar
it'll flash at whatever the rpm of the pill you have in it.
Old Nov 21, 2007 | 11:28 AM
thevtecnician's Avatar
Default Re: (ComeOnKip)
The tach wire on the back of the cluster is blue. There is also a black/yellow wire back there you could use for the power source. Its a 12v+ switched power source
Old Nov 25, 2007 | 08:19 PM
allmotorteg02's Avatar
tyler 100 thanks for askin the question i was researching also becauae i dont want one of those big dopey tachs in my view lol i want it ran through the stock tach but it dont make sense i think it will only work when u hit red line.
Old Dec 23, 2007 | 10:55 PM
tacorunner87's Avatar
Default Re: how to hook up a shift light.? (allmotorteg02)
Ok on my 88crx it looks to be blue w/ gray or green tracer and theres also a white w/ blue tracer can i stick an ohm meter or something on ther to test
or is it better to run it to the coil?
Modified by tacorunner87 at 12:10 AM 12/24/2007
Old Dec 26, 2007 | 03:40 AM
TiMiD703's Avatar
is there a way where you can adjust it to light up at a certian RPM?
Old Dec 26, 2007 | 09:08 AM
LIMITLESS22's Avatar
Default Re: (TiMiD703)
If you use an autometer shift light or something like it, the light is activated by a "pill" which you plug into the light. These "pills" are availabe in different rpm's. To change the activation of the light you just insert a different "pill"
Old Dec 26, 2007 | 09:42 AM
Hanmin's Avatar
some tach lights work through vibration, there should be an adjuster **** some where on the light.
Old Dec 26, 2007 | 05:38 PM
IMALLSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyler100 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if anybody would know how to hook up a shift light to a stock tach?
I have searched and haven't found anything. I found one post but it diddnt really tell how to do it. I got the shift light off a junk ebay tach that i got and the tach was fried and i don't want a gaudy tach on my dash. so i was thinking i could just wire up the shift light off of it. -TYLER</TD></TR></TABLE>
If you are running just the shift light off of a broken tach,you cant. The tach sends the signal to the light. No wiring is available. You should have two black wires right? Am I on the right path? This isnt a stand alone shift light with RPM pills? If it is then I must have misread the post.
Old Dec 26, 2007 | 06:33 PM
hondamn1320's Avatar
Default Re: how to hook up a shift light.? (IMALLSLO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMALLSLO &raquo;</TD></TR><TR><TD CLASS="quote">
i think you are right.
what you can do is buy a set of those pills and grab the one for the RPM you want the shift light to turn on. then cut one of the wires in half and connect each side of the wire to each side of the pills prong. and that should work. i used one of those autometer shift lights that take the pill and altered it to how i wanted it. the bulb is in the top of the cluster and shines down onto the tachometer, so there is no bright light in my face but i still know when to shift. :D
SAMCRO08
Oct 19, 2013 10:40 AM
Scotty Dosent Know
Audio / Security / Video
Feb 23, 2010 03:49 PM
j_kevin_ca
26
Oct 14, 2004 10:13 AM
kingSfit
14
Feb 10, 2004 04:48 PM
civicmark
Jul 5, 2002 03:06 PM
