Quick Question concerning acceleration
Old Nov 21, 2007 | 06:59 AM
delprad's Avatar
Default Quick Question concerning acceleration
im getting this weird vibration when i accelerate the steering wheel and whole car shake when this happens i was thinkin balljoints and tierods i have a broken stud on my drivers side front wheel would this cause the problem??? or am i right saying its balljoints or could it be even worse saying a motor mount or tranny mount???thanks
Old Nov 21, 2007 | 07:23 AM
YeuEmMaiMai's Avatar
Default Re: Quick Question concerning acceleration (delprad)
replace the stud and rim on that side of the car and you should be good to go
Old Nov 21, 2007 | 08:29 AM
delprad's Avatar
Default Re: Quick Question concerning acceleration (YeuEmMaiMai)
replace the rim????
Old Nov 21, 2007 | 09:44 AM
TheMuffinMan's Avatar
He knows where you live!
How long has it been broken?
That wheel could be warped from it over time
Old Nov 21, 2007 | 10:05 AM
delprad's Avatar
i have no idea like i sai di bought it that way i have new stud and lugnut just needs to be put in it is hard?
Old Nov 21, 2007 | 10:50 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (delprad)
some cars you can install the stud without removing the hub and some you need to remove the hub.
Try searching the archives, there has been discussions on it before. You'll see if you can is able to do it on the car or not.
Also, it's always best to list the year/trim when asking for help. Sometimes it's useful to include if it's a swapped engine and if it's auto or manual.
Old Nov 21, 2007 | 10:54 AM
delprad's Avatar
it is a 1994 accord ex with the sohc vtec it is a replaced motor as the PO hydrolocked the original one
Old Nov 21, 2007 | 11:06 AM
H-T Order of Merit
You didn't need to list the engine in this thread, I was more saying that due to the lack of that info in your other thread about the leaking oil.
from what I can find in the archives is that on the 94-97 Accords you should be able to pound the old one out and then pound/pull the new one in.
You remove the rim/tire as well as the caliper and maybe bracket (I dunno) and you should then be able to just hammer the old one out. Then to install the new one you may be able to hammer or you could use washers and the lug nut to pull the stud through and into place.
I've never done this so I'm not 100% sure it'll work, just going off what I can find in the archives.
Old Nov 21, 2007 | 11:49 AM
yes you replace the rim becuase on 3 lugs and that kinda of vibration you are gonna warp the holes in the rim for the lug studs. you might end up replacing more than the broken stud if the other ones have tread damage
Old Nov 21, 2007 | 12:16 PM
Rainmaker's Avatar
Why not:
1) Swap that rim with a rear one. Drive around and see if the vibration has changed. If not, then the problem is not in the rim. If it does change, then
2) Take the rim to a tire shop and ask them to rebalance it. If it balances fine, great. OTHERWISE replace the rim.
Old Nov 21, 2007 | 01:59 PM
Default Re: Quick Question concerning acceleration (Rainmaker)
you cannot rebalance a rim where the lug mounting holes have been damaged.......
_Keith_
Aug 1, 2008 12:16 PM
pinoyboy204
Apr 13, 2007 01:53 PM
coronadrinker
Oct 18, 2005 06:14 PM
boostin4door
Feb 14, 2004 12:00 PM
93darkEG
Oct 10, 2003 09:52 AM
