Mini_me questions?
Old Nov 21, 2007 | 06:09 AM
1FSTNDN's Avatar
Default Mini_me questions?
I am in middle of doing mine-me swap, and having few issues. I have d16a6 block and d16z6 head. I am using d16z6 timing belt and it's not fitting. All of the write up about doing mine-me swap said all i need is timing belt. My buddy told me i have to swap out water pump out also. I went ahead and got d16z6 pump from honda, when i counted the teeth on it, it's same as my old pump. Have someone gone thru this problem before?
Old Nov 21, 2007 | 06:28 AM
mr.speaker's Avatar
Default Re: Mini_me questions? (1FSTNDN)
from experience,the d16z6/d16y8 belt does work,but it's really tight and you might need to take off the spring on the tensioner..The d15b7 belt fits better..
Old Nov 21, 2007 | 06:32 AM
1FSTNDN's Avatar
Default Re: Mini_me questions? (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">from experience,the d16z6/d16y8 belt does work,but it's really tight and you might need to take off the spring on the tensioner..The d15b7 belt fits better..
d15b7 belt is not tight like z6/y8 belt?
Old Nov 21, 2007 | 06:35 AM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FSTNDN &raquo;</TD></TR><TR><TD CLASS="quote">
d15b7 belt is not tight like z6/y8 belt?</TD></TR></TABLE>
it has a 2 more teeth,gives alittle more room but still tensions just fine.
Old Nov 21, 2007 | 06:36 AM
1FSTNDN's Avatar
thanx i will try that...
Old Nov 21, 2007 | 06:37 AM
mr.speaker's Avatar
what are you going to do with the waterpump?
By the way,thats a nice crx you have.
Old Nov 21, 2007 | 06:38 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">what are you going to do with the waterpump?
By the way,thats a nice crx you have.</TD></TR></TABLE>
I say use it. Might of been pricey, but hey, a fresh waperpump can't hurt.
Old Nov 21, 2007 | 06:46 AM
1FSTNDN's Avatar
My old pump only has about twelve hundred miles on it, i have buddy at honda he took it back today.. and just called him he is going to get d15b7 belt. I am going to repaint the car, i am thinking about doing jdm front end on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
I say use it. Might of been pricey, but hey, a fresh waperpump can't hurt.</TD></TR></TABLE>
true
Old Nov 28, 2007 | 07:11 PM
1FSTNDN's Avatar
Thanx for info again D15b belt worked, little bit tight but alot better then d16z6 belt..
Old Nov 28, 2007 | 07:18 PM
gator88's Avatar
i thought the belts would work if you had the matching tensioner? Like y8 tensioner with y8 belt, z6 w/zt etc? Just wondering..
Old Nov 29, 2007 | 08:31 AM
1FSTNDN's Avatar
Default Re: Mini_me questions? (gator88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 &raquo;</TD></TR><TR><TD CLASS="quote">i thought the belts would work if you had the matching tensioner? Like y8 tensioner with y8 belt, z6 w/zt etc? Just wondering.. </TD></TR></TABLE>
I don't know, because all of the mini-me write up i read did not mention about tensioner needing to be changed.
B16Civic93
Jul 19, 2010 05:00 PM
1QwIkEf
17
Dec 18, 2008 07:49 AM
Archidictus
Mar 9, 2006 06:41 PM
Eg Smurf
Jul 23, 2004 06:57 PM
SleepyHF
Apr 1, 2004 06:47 PM
