How do you swap an OBD2(civic si) into an OBD1(1992 hatch)? Do I need to convert od change anything?
Old Nov 20, 2007 | 03:29 PM
vechai's Avatar
Default How do you swap an OBD2(civic si) into an OBD1(1992 hatch)? Do I need to convert od change anything?
I don't really know what to do. Should i change or need anything....should i convert or re-wired my harness...tell me
Old Nov 20, 2007 | 04:00 PM
ekb16's Avatar
i think you need to search
Old Nov 26, 2007 | 03:41 PM
vechai's Avatar
Default Re: (ekb16)
what u mean
Old Feb 15, 2008 | 10:09 AM
lilo_goki's Avatar
u don't need to do anything, i'm not sure if the civic si engine harness will fit into the eg shock towers, but the integra obd2 engine harness does fit though. u have two choice, either one, get an integra gsr engine harness and plug and play or two, convert ur engine to obd1. that is intake manifold, alternator, distributor, injectors, and etc. but if u don't want to deal with so much stuff, just go ahead and get an integra gsr engine harness and you'll be good to go. be sure ur using a obd1 ecu though, u'll be needing a usdm p30 ecu off of del sol b16vtec to pass ref'd and smog.
readyjetsgo
24
Oct 3, 2014 10:14 AM
mudko3
Feb 10, 2014 05:48 AM
Choy
Feb 25, 2010 03:07 PM
B16a2Wa
18
Jan 24, 2010 08:10 PM
hondarookie10
Oct 26, 2003 06:14 PM
