1.85L set-up blown...what's next?
Old Nov 20, 2007 | 10:44 AM
DA_JDM's Avatar
Default 1.85L set-up blown...what's next?
Hi guys,
My motor died on me last august and now im doing a complete rebuilt...and my first choice was to go 1.9L(82mm)...how should the difference be overall compared to my 81.5mm built??? I will have same header, same cams, same CR ratio(12:5:1), same ported head...i just need to re-sleeved the damaged sleeve and i dont know if the 82mm is going to be a good choice overall???
Thanks in advance for your suggestions
Mike
Modified by DA_JDM at 12:51 PM 11/20/2007
Old Nov 20, 2007 | 10:47 AM
all-mtr-teg's Avatar
Default Re: 1.85L set-up blown...what's next? (DA_JDM)
If you're planning on resleeving why not go 84mm or bigger? You'll have at least a 2.0L
Old Nov 20, 2007 | 11:13 AM
mar778c's Avatar
Community Builder
Community Influencer
all-mtr-teg is right, if your going to sleeve then you should go to 84 mm.
wiseco piston 11:5 compression
What type of cams, header, exhaust?
Old Nov 20, 2007 | 11:21 AM
DA_JDM's Avatar
Default Re: 1.85L set-up blown...what's next? (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">all-mtr-teg is right, if your going to sleeve then you should go to 84 mm.
What type of cams, header, exhaust?</TD></TR></TABLE>
SMSP Header design for a 1.8L motor not a 2.0L...Cams are JUN 3, exhaust is the RS-R GT2 catback system...
Old Nov 20, 2007 | 11:36 AM
mar778c's Avatar
Community Builder
Those parts are pretty good.
Sounds like all you really need is a short block re-sleeve and rebuild.
Old Nov 20, 2007 | 11:52 AM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Those parts are pretty good.
But actually i only need one sleeve re-done and the other one's are fine...after i need to oversized...so i guess the 82mm is my best choice if i dont wanna spend another 1000$ on a dart block...
Old Nov 20, 2007 | 12:06 PM
Natural Aspirations's Avatar
Your cheapest option is to pick up another LS block and buy one new piston. Dont spend the money to have the sleeved repaired when the price of another LS block is so low.
Old Nov 20, 2007 | 12:21 PM
h0ndap0w3r's Avatar
that sounds like your best bet. . .for a bore n hone it shouldnt cost more than like 100 bucks. LS blocks also go for around 100-200 bucks ne who
Old Nov 20, 2007 | 12:23 PM
DA_JDM's Avatar
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">Your cheapest option is to pick up another LS block and buy one new piston. Dont spend the money to have the sleeved repaired when the price of another LS block is so low.</TD></TR></TABLE>
I prefer to keep my ITR block!!! I will only repair the sleeve and bore it to 82mm with Wiseco 82mm pistons!!! The main question was not to see if i wanna change my block...it was only to know if the feeling of my motor will change a lot and is the power gonne be almost the same???
Old Nov 20, 2007 | 12:40 PM
Default Re: (DA_JDM)
Similar. You will not notice any difference.
What happened to the motor?
Old Nov 20, 2007 | 01:36 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">Similar. You will not notice any difference.
What happened to the motor?</TD></TR></TABLE>
Dropped valves
Old Nov 20, 2007 | 01:39 PM
h0ndap0w3r's Avatar
sorry i was under the impression that you had an LS block, not an ITR. Since u have an itr block i would want to keep it to, for the simple fact it says b18c5. . .=P, as for the change from 81.5-82mm, almost no change at all, maybe pick up a lil tq n some hp, but thats about it.
2.0L is where its at in the all motor field
Old Nov 20, 2007 | 01:46 PM
DonF's Avatar
Default Re: (h0ndap0w3r)
A single sleeve, back to stock is $80.00-$100.00. It just replaces what was there, not putting in Darton or GE sleeves on all cylinders.
Old Nov 20, 2007 | 03:18 PM
DA_JDM's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">A single sleeve, back to stock is $80.00-$100.00. It just replaces what was there, not putting in Darton or GE sleeves on all cylinders. </TD></TR></TABLE>
I know...ive called my builder...i was thinking he had to re-done all the sleeves...so i will stick 82mm instead of 84mm!!!
Old Nov 20, 2007 | 03:20 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0ndap0w3r &raquo;</TD></TR><TR><TD CLASS="quote">
2.0L is where its at in the all motor field</TD></TR></TABLE>
Ive done 215whp on a roller mustang dyno with the 1.8L!!! I know i can pickup more HP with a 2.0L but i love to have those big # and still be 1.8L
Old Nov 21, 2007 | 07:58 AM
DA_JDM's Avatar
Default Re: 1.85L set-up blown...what's next? (all-mtr-teg)
Im sure there's some 82mm built on here...owners feel free to list you set-up and your impressions
Old Nov 24, 2007 | 04:00 PM
h0ndap0w3r's Avatar
i know i know, there are some ppl who made alot of power with 1.8's. . . eugene from prostreet made something like 215 with an lsvtec. . . but different strokes for different folks. . . gl on the build man
Old Nov 24, 2007 | 04:01 PM
h0ndap0w3r's Avatar
oh we just dyno'd a type r with valve train and skunk pro 1's. . . made 193 with a stock itr exhaust, stock bottom end, blah blah blah just added cams and hondata
Old Nov 26, 2007 | 11:17 AM
DA_JDM's Avatar
Is 82mm safe on OEM sleeve???
Old Nov 26, 2007 | 12:14 PM
200+ WHP on my 12:1 82
Old Nov 26, 2007 | 12:17 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">200+ WHP on my 12:1 82 </TD></TR></TABLE>
Are you on OEM sleeve???
Old Nov 26, 2007 | 12:21 PM
Yep, no reason to sleeve and go 82.
Old Nov 26, 2007 | 02:02 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">Yep, no reason to sleeve and go 82.</TD></TR></TABLE>
Why are you so sure??? Do you think its gonna last long???
Old Nov 26, 2007 | 02:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">
Why are you so sure??? Do you think its gonna last long???</TD></TR></TABLE>
Cause I said so, christ do some research. The life of anything is dependant of the quality of parts, use and treatment. It shure the hell wont hold up any less to a dropped valve than your last motor.
Type Argh for life
Old Nov 26, 2007 | 04:19 PM
DA_JDM's Avatar
Type Argh for life</TD></TR></TABLE>
Your funny...but in the same time you act like a little boy...i need serious advice please
STEVE-O7
12
Oct 9, 2007 09:33 AM
crxsimike
Apr 5, 2006 11:34 AM
Beau Gotti
13
Feb 11, 2006 01:37 PM
SpoolnEG6
May 29, 2005 02:21 PM
emotionisdead
10
Oct 19, 2004 08:37 AM
