Fouled plugs cleaning and re-use?
Old Nov 20, 2007 | 08:03 AM
elpiar's Avatar
Default Fouled plugs cleaning and re-use?
I got 8 plugs that was fouled to some ECU problems and end up being too rich.
Can I clean them up and re-use them?
sand them and use brake cleaner? (These are BKR7E btw)
Old Nov 20, 2007 | 08:19 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Fouled plugs cleaning and re-use? (elpiar)
They're EIGHT dollars for a new set.
Old Nov 20, 2007 | 08:21 AM
elpiar's Avatar
Default Re: Fouled plugs cleaning and re-use? (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">They're EIGHT dollars for a new set.
I know. but it does not answer my question
Old Nov 20, 2007 | 08:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">
I know. but it does not answer my question </TD></TR></TABLE>
Actually I did.
It's NOT worth it, so DON'T do it.
Old Nov 20, 2007 | 08:32 AM
tokesGTR's Avatar
Yeah it does. He's trying to say nicely that you shouldn't be a cheap *****. I never like to chance my motor to stupid **** like that, how dumb would you feel if an electrode broke off and ruined a valve, piston, or turbine wheel?
Old Nov 20, 2007 | 08:35 AM
93supercoupe's Avatar
Default Re: Fouled plugs cleaning and re-use? (tokesGTR)
i get what ur saying, they were covered in soot and ur wondering if u clean them, are they still good.
I thiknk the answer depends on how long they were in and was running rich the only thing wrong with the tune?
What im getting from everyone elses post is that a spark plug is coverd with soot its not good, but no one can explain why.
I guess when my car gets dirty its time for new one, until i hear reasons otherwise.
Old Nov 20, 2007 | 08:39 AM
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokesGTR &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah it does. He's trying to say nicely that you shouldn't be a cheap *****. I never like to chance my motor to stupid **** like that, how dumb would you feel if an electrode broke off and ruined a valve, piston, or turbine wheel?</TD></TR></TABLE>
Did I say that I will put the fouled plugs in my boosted motor?
Did I even mention what my ride is? what if I'm gonna put it in a $200 car that still runs?
I am asking a question about plugs, not about budgeting on a turbo project. If you don't know the answer to this, please do not post.
Old Nov 20, 2007 | 08:44 AM
I am asking a question about plugs, not about budgeting on a turbo project. If you don't know the answer to this, please do not post.</TD></TR></TABLE>
Wow...good luck getting any help with that attitude buddy.
I wouldn't put used plugs in my $400 beater Camry wagon, my DD Acura TL, or my turbo ITR-powered civic.
Just throw them away and move on, used plugs FTL.
Old Nov 20, 2007 | 08:45 AM
tokesGTR's Avatar
If you're putting it in your boosted car, get new plugs.
If you're putting it in a 200 dollar car that still runs, go spend 10 bucks on a new set of champions.
Don't be a cheap ******. Who cares if it's for a 200 dollar car, you run the risk of it running like complete *** to save as much money as you'd spend on a shitty lunch at McDicks.
Old Nov 20, 2007 | 08:46 AM
elpiar's Avatar
Default Re: Fouled plugs cleaning and re-use? (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">i get what ur saying, they were covered in soot and ur wondering if u clean them, are they still good.
I guess when my car gets dirty its time for new one, until i hear reasons otherwise.</TD></TR></TABLE>
Thanks for focusing on the question, unlike most kids in here.
Yea it's only been in the car for 10 minutes, and gets very rich due to the ECU being in limp mode.
Anyone got any experiences cleaning up spark plugs?
Old Nov 20, 2007 | 09:11 AM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">Anyone got any experiences cleaning up spark plugs?</TD></TR></TABLE>
Yes, and the car ended up running like *** every time I tried it. Hence why you should go and spend 10 bucks on new plugs.
Old Nov 20, 2007 | 09:23 AM
Boner_Ben's Avatar
I clean up old sets to drive around on or move the car around. I always put in a new set before racing though. Back in the day I just cleaned plugs with carb cleaner and never had a problem
bigbadboy's Avatar
yea they will mostly like just foul out again. its only acceptable to re-use them if you get stranded somewhere because of it and you need to make it home. thats the only reason i would/had to do it. i had to do it once and it sucked. cause they keep ******* up again i had to stop constantly to clean them off. luckly i always carry a little piece of sand paper and some parts cleaner lol. but no don't do it even if its your $50 beater. there now you heard from a person with 1st hand experience now go and buy u some new ones.
Old Nov 20, 2007 | 09:31 AM
D@nnY's Avatar
theres nothing wrong with cleaning the plugs. I use a matco air tool spark plug cleaner all the time.
Old Nov 20, 2007 | 09:32 AM
D@nnY's Avatar
fat chance of that from cleaning some new plugs.
Old Nov 20, 2007 | 10:30 AM
quicksilver1689's Avatar
i ♥ snails
yeah carb cleaner and a wire brush always worked, unless they have signs of stress or it looks as they coud fail physically replace, if there dirty just clean them.
Old Nov 20, 2007 | 10:44 AM
SOHC_MShue's Avatar
if you are still having ecu problems then keep cleaning them until you figure that out, but once its fixed I would just go buy some new ones. They arent expensive at all so why not?
Old Nov 20, 2007 | 01:45 PM
MidShipCivic's Avatar
Default Re: Fouled plugs cleaning and re-use? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">if you are still having ecu problems then keep cleaning them until you figure that out, but once its fixed I would just go buy some new ones. They arent expensive at all so why not?</TD></TR></TABLE>
I agree I kept fouling plugs on my DSM.. and it was a stupid faulty fuel pressure gauge I bought like 6 sets of plug...before I fixed the prob I could've just cleaned the plugs off and reused them.
Old Nov 20, 2007 | 02:00 PM
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">theres nothing wrong with cleaning the plugs. I use a matco air tool spark plug cleaner all the time. </TD></TR></TABLE>
Now dont u guys feel dumb.HAHA.
I think its apperent that when dealing with a setup u want to keep around, u use all good parts, but calling the dude dumb and cheap and not giving ANY reasons to why is way more dumb and cheap than the OP.
Thank u Danny.
Old Nov 21, 2007 | 07:30 AM
elpiar's Avatar
Default Re: (93supercoupe)
Thank u Danny.</TD></TR></TABLE>
That's right.
That's what I'm doing until I figure out my ECU problem.
Thanks for all the answers guys.
Old Nov 21, 2007 | 09:19 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: (elpiar)
yes you can clean and reuse them. i have done it a thousand times
Old Nov 21, 2007 | 10:46 AM
HiProfile's Avatar
I wouldn't put used plugs in my $400 beater Camry wagon, my DD Acura TL, or my turbo ITR-powered civic. </TD></TR></TABLE>
THey sold the plugs I had bought over the phone when I got to the dyno. I still made 60whp over stock NA power with a tiny turbo, 6psi, stock exhaust & cat, crappy manifold, 1 point lower compression pistons, and OLD, CHEAP, *STOCK* PLUGS. They even said I could have added 2 degrees of timing.
In other words, they'll work in a pinch, but don't expect much besides simple combustion.
BTW if this wasn't for a boosted car, it should have been in the TECH section, not FI.
Old Nov 21, 2007 | 01:39 PM
D@nnY's Avatar
Default Re: Fouled plugs cleaning and re-use? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
BTW if this wasn't for a boosted car, it should have been in the TECH section, not FI. </TD></TR></TABLE>
sorry mom
Old Nov 21, 2007 | 01:42 PM
Schister66's Avatar
Man U FTW
I've reused plugs a couple of times...fouled during a tune but were new before it. I just washed them off with some brake cleaner and a bit of sandpaper...they worked fine for another 3k miles
killacam661
Oct 1, 2007 10:28 AM
Initial DA6
Feb 9, 2006 08:01 PM
mimesis
Mar 30, 2005 04:32 AM
coupon
Feb 11, 2005 03:58 PM
JICB16B
44
Sep 26, 2003 07:34 AM
