evo h2b half moon adapter ?
Old Nov 19, 2007 | 11:57 PM
honda_ef9's Avatar
Default evo h2b half moon adapter ?
im going to be starting my h2b project this week for my 95 coupe.Im starting to buy my parts needed and i noticed the evo kit has 2 adapter plate avaliable, the full plate and half moon. Also there is a 150 dollar difference. My question is, what is the real difference in the two plates other then price and the obvious, one being half moon and the other full? THANKS HT in advance
Old Nov 20, 2007 | 12:24 AM
honda_ef9's Avatar
also would like to know what problems i may run into using inovative b series mounts with the evo kit rather then the provided mounts from evolution
Old Nov 20, 2007 | 01:24 AM
cartune network's Avatar
Default Re: (honda_ef9)
the mounts should be fine. doesnt the evo kit offer hasport mounts? if it does than its the same thing a b-series mount is a b-series mount.
Old Nov 20, 2007 | 02:14 AM
ExospeedAMcrx's Avatar
Default Re: (cartune network)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote">the mounts should be fine. doesnt the evo kit offer hasport mounts? if it does than its the same thing a b-series mount is a b-series mount.</TD></TR></TABLE>
the evolution kit uses their own mounts. The mounts with the kit are designed specifically to work with the kit and position the engine and trans at a certain angle to clear the hood.
Old Nov 20, 2007 | 08:23 AM
dookieK9's Avatar
Default Re: (ExospeedAMcrx)
so you could use the regular hasport b mounts if you dont care about hood clearance? i would like to know also planning to to go h2b too
Old Nov 20, 2007 | 09:43 AM
Default Re: (dookieK9)
BEst to go with the full Evolution kit so there are no mix and match issues. remember the mounts were made to fit a certain way with a B trans and H motor. the angles are different from a regular swap. if you go with another company's mounts, one may fit, the others may not fit properly.
Old Nov 20, 2007 | 12:05 PM
honda_ef9's Avatar
damn anyone else wanna touch on this subject??
Old Nov 20, 2007 | 12:09 PM
Natural Aspirations's Avatar
Exospeed answered your question completly... Go ahead and cheap out mix it up and have to replace the parts that dont fit correctly.
Old Nov 20, 2007 | 12:17 PM
honda_ef9's Avatar
Default Re: (Natural Aspirations)
i also asked about the bisi plate. And i wanted know if anyone has had any personal experiance with using different mounts with this kit
Old Nov 20, 2007 | 12:51 PM
2fastGSR's Avatar
King of the One Liners
when purchasing the evo kit you must use evo mounts plain and simple.
If you would like to go with different mounts then go with the QSD plate....
Old Nov 20, 2007 | 12:52 PM
honda_ef9's Avatar
thank you sir
Old Nov 21, 2007 | 05:55 AM
Bisimoto's Avatar
Evo Full moon, or signature Bisimoto half moon? It is up to you, the consumer. I run and prefer the half moon as it mimics the engine, and offers some weight savings. The very first honda-to-honda drag adapter plate that I designed was of half moon variety, and hence the "signature-series". Some people prefer the Evo full moon that mimics the trasmission. With either choice you wll get the quality and precision that your deserve.
BTW, do not skim on parts: the complete kit is the way to go. I hope that helps.
Old Nov 21, 2007 | 10:49 AM
Default Re: (Bisimoto)
not exactly on topic but similar subject.
Here's the first pic out of the Evolution EK adapter kit.
Disco Monkey
May 3, 2004 04:49 PM
alexdog69
Apr 6, 2004 07:04 PM
eddiecut
10
Jul 17, 2003 09:29 PM
RedlineRex
Jun 13, 2003 09:28 PM
CRXBart
Apr 3, 2003 10:46 PM
