HIDs flicker....Battery or Alternator???
Old Nov 19, 2007 | 10:25 PM
yoshe95si's Avatar
Default HIDs flicker....Battery or Alternator???
My car has about 124,000 miles on it. Never replaced the alternator so it's still stock. My voltage reading is usually around 13.6 to 13.8 when I'm driving around but sometimes drops lower. But when car is off, the battery reads 12 volts. I also have a stereo with a powered 10 inch subwoofer and powered after market door and rear speakers. I've got aftermarket HIDs hooked up directly to the battery with relay. HIDs are still flickering from bright to dim. I'm guessing I'm not getting enough power to the ballast. Should I upgrade my battery to a stronger battery, or upgrade my alternator, or just upgrade both? Or maybe I just have a cheap HID kit.
Old Nov 19, 2007 | 10:27 PM
93egSLEEPER's Avatar
Default Re: HIDs flicker....Battery or Alternator??? (yoshe95si)
sounds like a ballast is losing some power so id check that. bad alternator would make the car hard to start... same with battery. probably the hid kit.
Old Nov 20, 2007 | 06:32 AM
EK_B's Avatar
Default Re: HIDs flicker....Battery or Alternator??? (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a ballast is losing some power so id check that. bad alternator would make the car hard to start... same with battery. probably the hid kit.</TD></TR></TABLE>
Thinking the same thing, ballasts.
Old Nov 20, 2007 | 08:37 AM
2mansi's Avatar
yeah you need to get a cap for your sound sysytem. Also i hate to say this but it sounds like the ballast may be going out. This happened to me and i thought the ballast was not getting enough power but finally the ballast gave out and the lights would not even turn on.
Old Nov 20, 2007 | 10:13 AM
whitecivic11's Avatar
same thing happened to me my hids kept flickering when i turned them on it ended up being the alternator
Old Nov 20, 2007 | 02:14 PM
yoshe95si's Avatar
Cool thanks guys! I ordered a newer HID kit. My current kit I have now, I'm not to happy with. I'll look into getting my alternator tested at the Honda dealer too.
Old Nov 20, 2007 | 02:23 PM
HAPRECYCLING's Avatar
DOES YOU KIT USE DIODES?
Old Nov 20, 2007 | 09:18 PM
yoshe95si's Avatar
How would I know that?
Old Nov 24, 2007 | 10:32 AM
does your kit have the high beam low beam HID? I had the same problem w/ flickering and my diode was not big enough. Put a bigger diode in and fixed the problem.
im using aftermarket bulbs with factory ballast from a Tl
Old Dec 1, 2007 | 09:03 AM
yoshe95si's Avatar
Got a new HID kit with Hi's and Low's from XenithXenons and have no issues so far, and the lights are bright!
htsang07
Lighting
Jul 15, 2008 10:07 AM
BoltonGSR
Jul 7, 2008 08:27 PM
calean
Nov 18, 2004 03:55 PM
mjrage
18
Jun 25, 2004 06:28 PM
tallblondkid
15
Jan 26, 2004 07:28 AM
