can anyone help??? my integra vibrates as i accelerate...
Old Nov 19, 2007 | 10:47 AM
streetlights's Avatar
Default can anyone help??? my integra vibrates as i accelerate...
does anyone know what the problem may be...as i accelerate usually around 60-80 mph in 5th gear my integra starts to shake or vibrate...its not excessively, but it does move around a bit...it also doesnt do it all the time...does anyone know what the problem may be?
Old Nov 19, 2007 | 11:46 AM
jomama's Avatar
where's it coming from? more details?
Old Nov 19, 2007 | 11:51 AM
jgirard's Avatar
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">where's it coming from? more details?</TD></TR></TABLE>
Definitely need more details, could be a lot of diffenrent things
Old Nov 19, 2007 | 11:54 AM
Jon D's Avatar
Default Re: can anyone help??? my integra vibrates as i accelerate... (streetlights)
Does it only shake under throttle? Could be a bunch of things as others have stated. Also... only in 5th gear?
Old Nov 19, 2007 | 11:56 AM
Cheeze's Avatar
Default Re: can anyone help??? my integra vibrates as i accelerate... (Jon D)
Could be your tires needs balancing or among other things.
Old Nov 19, 2007 | 12:04 PM
donz's Avatar
Default Re: can anyone help??? my integra vibrates as i accelerate... (Cheeze)
that is what I think too. see if it is vibrating in 5th gear only... ie take the car for a ride at 50-60 in 4th gear, or go a little faster in 5th and pop it out of gear and see if the vibration goes away... if it does, easy fix, go to your tire shop and have it balanced.
Old Nov 19, 2007 | 12:40 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: can anyone help??? my integra vibrates as i accelerate... (donz)
could be the inner joint of the cv, mine did it at all speeds basically at a certain throttle position
Old Nov 19, 2007 | 01:20 PM
Default Re: can anyone help??? my integra vibrates as i accelerate... (Mr.OB*GYN_Rhett)
it vibrates and makes a faint rattling noise in 4th gear...but more in 5th gear...it stops when i get off of the pedal...also it doesnt happen all the time and is kinda subtle so its hard to figure it out...i thought it was my tire needing to be balanced, or my wheel was bent...but if that were true wouldnt it shake/vibrate at all speeds?
Old Nov 28, 2007 | 08:03 AM
just got my wheels checked out and it seems like my tires were balding and there was a bump on one tire...so i bought new tires...now theres no vibration but there is still that kind of knocking noise when i step on the gas in about 4th gear...the noise isnt always there, it seems like it comes up if i drive the car for a while...
anyone have any ideas what it could be?
jdelacruz129
Jan 30, 2017 01:36 PM
Sytar69
May 28, 2006 10:20 PM
DaZman69
Nov 23, 2005 01:16 PM
