brakes kinda weird after swap.
Old Nov 19, 2007 | 08:08 AM
lilo_goki's Avatar
Default brakes kinda weird after swap.
this is weird, i knoe that brakes doesn't have anything to do with the engine, but after i did my ls swap. when i start the car, drive it and press on the brake, brake would not work, it would just be dead, i have to double pump it for it to work. then later on while driving, it'll start to work. i have to do that everything i restart the car. weird, anyone ever had the same problem?
Old Nov 19, 2007 | 08:20 AM
23-10's Avatar
Default Re: brakes kinda weird after swap. (lilo_goki)
Is the brake booster vacuum hose connected properly?
Old Nov 19, 2007 | 09:08 AM
lilo_goki's Avatar
yea i'm pretty sure. i don't think i even touch that when i did the swap. i'll go check.
Old Nov 19, 2007 | 10:10 AM
jdmcivicracer89's Avatar
Default Re: (lilo_goki)
check your clutch slave cylinder...
Old Nov 19, 2007 | 11:01 AM
lilo_goki's Avatar
clutch slave cylinder. what can be wrong with it. why does the clutch slave cylinder affects the brakes.
Old Nov 19, 2007 | 02:52 PM
benzo_tek's Avatar
clutch has nothing to do with the brakes. Check the booster for sure and post back. Make sure you dont have a slight leak in a line also.
Old Nov 19, 2007 | 02:58 PM
awdgsx96's Avatar
Make sure you didn't damage the vacuum line to the brake booster. And make sure it is securely connected to the IM
Old Nov 19, 2007 | 10:31 PM
lilo_goki's Avatar
i'll check the brake booster and the vacuum line to the brake booster tomorrow. thanks.
Old Nov 20, 2007 | 03:19 PM
lilo_goki's Avatar
k i check the brake booster vaccum line and it's on tight. no leak. so what's wrong. i might just rebleed the brake.
kazaa187
May 26, 2013 01:51 PM
BoBo Racing
Apr 26, 2008 01:08 PM
jikespingleton
Jan 2, 2007 01:31 AM
Del_Sol_s
27
Mar 4, 2006 06:49 AM
veejay
Jul 24, 2001 09:39 AM
