Determining rod and main bearing colors.
Old Jun 24, 2002 | 05:56 PM
Prelude Vtec 23's Avatar
Default Determining rod and main bearing colors.
Ok guys I am having some trouble here. I have searched and looked in my helms but its a little confusing. Ok on the crank for the mains the numbers are as follows: 3 3 3 3 4, and for the rods its labeled 3 C C 4. Ok I dont know exactly how to correspond these to the helms chart they have. Can someone tell me what colors I need? Would it be best if I get the color code of the bearings itself. My main thing is how do I read the diagram in the helms.
Also the last number on both is 4. In the helms diagram on pages 7-9 and 7-11, they both point to the same bearing. One is for the main but the other is supposed to be for the rod. But on page 7-11 it points to the same thing as 7-9, can anyone explain that to me as well?
Thanks guys.
Old Jun 24, 2002 | 09:44 PM
kevie88's Avatar
Default Re: Determining rod and main bearing colors. (Prelude Vtec 23)
Damn.. my manual is at home. *bump* anyway and I'll post in the morning when I get home.
Old Jun 25, 2002 | 12:32 AM
aeolus's Avatar
Default Re: Determining rod and main bearing colors. (kevie88)
on the ones marked by two,there should be a number and a letter on the same area.look really carefully.i bet there are two more lettters you might have missed,the 3and 4 you have for the rod journals are the actually the ones for the mains.i bet all your rod journals are marked "c"
[Modified by aeolus, 9:35 AM 6/25/2002]
[Modified by aeolus, 9:41 AM 6/25/2002]
[Modified by aeolus, 9:44 AM 6/25/2002]
Old Jun 25, 2002 | 05:08 PM
Default Re: Determining rod and main bearing colors. (aeolus)
ttt anyone else???
Old Jun 26, 2002 | 07:25 AM
Come on guys nobody else can help me???
Also I am going to be replacing my rods w/ crower rods, can I still use the same color oem bearings?
Old Jun 26, 2002 | 08:15 AM
John's Avatar
New User
Trying PMing Todd (Todd 94) or Scott (2point6)...
Old Jun 26, 2002 | 10:14 AM
Smurfylude's Avatar
Default Re: Determining rod and main bearing colors. (DunReit)
Aleast your crank has numbers on it..... mmy JDM H23 vtec does not....
Old Jun 30, 2002 | 11:14 AM
sgT's Avatar
sgT
The crank should have 5 numbers and 4 letters.
For the Mains, the numbers read 33334, combine those with the letters that
are printed on the bottom of your block. For example. if you have ABABA,
then you would have A3,B3,A3,B3,A4 as a result
For rods, take the 4 letters on the crank, and combine that with the numbers
on the rods in the same fashion.
Old Jul 1, 2002 | 07:01 AM
Default Re: Determining rod and main bearing colors. (sgT)
Thanks sgT
Luded93
Apr 20, 2011 11:32 PM
92sihbk
Aug 8, 2007 10:40 AM
eklum
17
Apr 30, 2006 07:40 AM
InfamousRS
Feb 8, 2002 12:13 PM
t
Oct 4, 2001 09:20 PM
