do you have a B&M?
it is def a short throw. The throw itself is shortened, its not just the length. Its extremely short. 1st to second is like 1st to neutral.
I've heard not to throw it super fast, but man is it enjoyable. I haven't missed a gear with it yet. But they do "move" a bit from stock. Just don't try to force it back the way you do stock. It takes minimal effort to move it. I did the bushings at the same time. I can't move my shifter at all while its in gear like I could with the stock ones.
doesn't take long to do, just make sure you watch how you took it out and follow directions.
should take you an hour. I have a set. I just put a $20.00 shifter in my girlfriends integra and I think it is better than the B&M. Only because the cheapie shifter has a bend in it making it easier to reach.
is it hard to put the shifter and the bushings in? how much time should i expect to spend doing this?
JM Performance
Jan 23, 2002 04:14 AM
Makes for a enjoyable car experience!
