Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How to install a fan switch and others.....
Old Jun 24, 2002 | 05:23 PM
VTECAcuraGSR's Avatar
Default How to install a fan switch and others.....
Guys,
I want to create a fan over-ride switch that will turn my fans on regardless of what the sensor says. How do I do this.... I am sure its very easy but how do I wire it up by the fan? Also, I was looking into a fuel cut-off switch, but I was reading about how the fuel pump's gallonage is dependant upon how much power the pump gets. I would imagine that splicing and adding a switch would reduce the current even more and bottom line it would it be better to install an ignition kill? If so what do I need to do?
Old Jun 26, 2002 | 02:17 AM
Default Re: How to install a fan switch and others..... (VTECAcuraGSR)
I know you all know...... No one can help?
Old Jun 26, 2002 | 02:44 PM
Steve91's Avatar
This is very easy to do, but you need a factory manual to find the correct wires. Here's how I do them on Honda's: On the back of the block (not sure where its at on a GSR, hence the need for a factory manual) there is a thermo-switch. This is the switch that turns on the fans when the engine reaches a certain temp. This works by completing the ground to the fan relay when the swith is at the proper temp.
The thermo-switch has two wires attached to it. One comes from the fan relay and the other just goes to a body ground. You want to cut the one that comes from the fan relay and splice in a new wire, while still keeping the original wire connected to itself. Think of it like a "T" fitting in a vacuum line setup.
Now, feed this newly added wire into the cockpit of the car and connect it to the switch you are going to buy. Wire the other end of the switch to a good chassis ground.
Now, every time you flip the switch, the fan will come on, and if you forget, the fan will still come on when the motor gets hot enough to trip the thermo-sensor.
Old Jun 26, 2002 | 02:54 PM
Default Re: How to install a fan switch and others..... (Steve91)
Steve,
Thanks for the reply.. Appreciate it. I will look it up in my helms tonight. Does anyone have any ideas or thoughts about a fuel cut or kill switch?
Old Jun 26, 2002 | 03:06 PM
kb58's Avatar
Banned
You have the Helms, it's all in there. Check around the Main-FI relay (it's called that or something close.) It's where the pump is powered from. Best to put a switch on the coil side of that relay so you don't run high current through the switch.
Old Jun 27, 2002 | 09:02 AM
Steve91's Avatar
You can create a kill switch for any part of you car using a similar approach. Find the relay that controls ,the fuel pump, starter, ecu, etc. and cut the ground wire to the relay. Put a swith on that ground wire, in line, and you now have a kill switch. Simple and easy.
Old Jun 27, 2002 | 09:07 AM
B18CXr's Avatar
I'd toggle the fan via the ECU pinout, this way you utilize the factory relay and chit, cleaner install also.
Old Jun 27, 2002 | 09:11 AM
Default Re: How to install a fan switch and others..... (B18CXr)
Yack,
Can you elaborate more? What exactly do you mean? Are you saying to splice into the ECU signal wire to the thermo switch?
Old Jun 27, 2002 | 09:16 AM
B18CXr's Avatar
there is a one conductor wire at the ECU (not sure the label, maybe "FAN" or something, check you helms) it's either active low or high, not sure which (need my book infront of me)
very,very low current and the install keeps the engine bay clean,etc...
Old Jun 27, 2002 | 10:08 AM
chad's Avatar
Moderator
jacks car always looks clean......it's a show car!! (that's going to roll me at summit)
Old Jun 27, 2002 | 01:58 PM
Default Re: How to install a fan switch and others..... (Chad)
OK I am looking at my Helms as we speak and it appears as though there is one yellow/green wire that connects to the ECT. Would I splice this wire? This seems to be the signal wire not the ground.... Can anyone help? Yack or Steve?
Old Mar 1, 2004 | 11:08 AM
roydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">there is a one conductor wire at the ECU (not sure the label, maybe "FAN" or something, check you helms) it's either active low or high, not sure which (need my book infront of me)
very,very low current and the install keeps the engine bay clean,etc...</TD></TR></TABLE>
Back from the dead but I was wondering if anyone knew which color wire it is on the ecu on a 94 LS?
Old Mar 1, 2004 | 11:11 AM
JeffS's Avatar
Default Re: How to install a fan switch and others..... (roydogg)
To quote the person you quoted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">check your Helms</TD></TR></TABLE>
fraserboostedh22
Jan 27, 2018 01:35 PM
turbosivtec
Oct 21, 2008 06:19 PM
mackadocious
24
Jun 12, 2008 05:56 PM
shackler
12
Jun 21, 2007 06:17 PM
Ausmith
Aug 10, 2003 12:24 AM
