will 98 prelude ecu plug into 99 civic?
Old Nov 18, 2007 | 04:37 PM
Terrible One's Avatar
Default will 98 prelude ecu plug into 99 civic?
my friend has a 99 civic ex and i'm helping him swap a 98 usdm h22a4. i was wondering if the prelude ecu will plug into his civic and run.
Old Nov 19, 2007 | 04:33 AM
Default Re: will 98 prelude ecu plug into 99 civic? (Terrible One)
bump
Old Nov 19, 2007 | 04:42 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I don't think it will work for two reasons:
1. I know the 99 Civic has OBD2B plugs, and I think the 98 Prelude has the different OBD2A plug-type ECU.
Check the ECU and see if it will even plug in, if it does that brings me to my second point, which I am sure of:
1998 Prelude has an immobilizer ECU that requires a chipped key, and the corresponding ignition switch.
Old Nov 19, 2007 | 05:09 AM
1sickEJ's Avatar
i will work if u have a custom jumper harness..
Old Nov 19, 2007 | 06:51 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (1sickEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sickEJ &raquo;</TD></TR><TR><TD CLASS="quote">i will work if u have a custom jumper harness..</TD></TR></TABLE>
Yes it would plug in, but what would he do about the immobilizer? Can't start the engine without figuring out how to bypass the immobilizer...
Old Nov 19, 2007 | 06:59 AM
Nbboy7's Avatar
Just get a p28 chip for your set up
Old Nov 19, 2007 | 07:52 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (Nbboy7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nbboy7 &raquo;</TD></TR><TR><TD CLASS="quote">Just get a p28 chip for your set up</TD></TR></TABLE>
Few potential issues with that:
1. If he has to pass an emissions test to get a tag each year he'd be royally screwed
2. A P28 won't have EGR (not a big deal), but worse it won't have IAB/secondary butterfly controls to properly run the H22A with its stock manifold. now if he goes with an aftermarket or Euro R IM that does away with the IABs then this isn;t an issue either.
I mean sure he can go jumper harness with an OBD1 ECU of his choice, but emissions usually hampers most people from doing that.
Old Nov 19, 2007 | 10:33 AM
Tomdata's Avatar
Default Re: (B18C5-EH2)
Run a chipped P72 or modified chipped P28 for the IAB. Then put the stock ex civic ecu in before the emissions test and you should be fine.
PhatBoy5015
33
Oct 29, 2017 11:42 AM
blackccoupe
May 11, 2014 10:05 AM
vietdragontekx
Jan 7, 2008 11:56 AM
leadtrum
Aug 31, 2005 09:41 AM
2WYLD4U
Jun 10, 2003 03:32 PM
