Rear Seat REMOVAl Trick?
Old Nov 18, 2007 | 02:30 PM
blackh23's Avatar
Default Rear Seat REMOVAl Trick?
i know how to remove the rear seats, well i think i do. But the two pins under each rear seat won't pull out. I've already pulled both the outer pins by the windows but the pull pins closer to the armrest will not pull out. Did anybody run into this problem or am i forgetting something?
i've almost lost my index finger with these two.
Old Nov 18, 2007 | 02:33 PM
95greenlude's Avatar
Default Re: Rear Seat REMOVAl Trick? (blackh23)
i'm assuming you have a 4th gen.....
try not to pull up on the seats while pulling on the tabs....try pushing down....
Old Nov 18, 2007 | 05:59 PM
socalSH's Avatar
Default Re: Rear Seat REMOVAl Trick? (Acidcrakker)
Yeah i used needle nose pliers and a very small flat head to push up the wire holding in the pin
Old Nov 18, 2007 | 06:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Ive used Vice grips before</TD></TR></TABLE>
i dont know if vice grips are a good idea.....i wouldnt want to risk breaking the tabs
Old Nov 18, 2007 | 06:42 PM
M2B4's Avatar
Default Re: Rear Seat REMOVAl Trick? (95greenlude)
ive always just used flat head, but ive pulled them all the way out a few times.
Old Nov 18, 2007 | 06:47 PM
ludekid4323's Avatar
Default Re: Rear Seat REMOVAl Trick? (M2B4)
I just broke my plastic tabs off
Old Nov 18, 2007 | 06:50 PM
M2B4's Avatar
Default Re: Rear Seat REMOVAl Trick? (ludekid4323)
did you break them or pull them out? ive pulled mine out but i got them to push back in.
Old Nov 18, 2007 | 07:13 PM
mgags7's Avatar
It is very easy to get these out if you just follow Jared's advice, push down hard.
Old Nov 19, 2007 | 09:49 AM
blackh23's Avatar
Default Re: (mgags7)
Yup, i din't realize how easy it was to take them off. All i had to do was push down on the seats and pull the tabs at the same time. Now i have 5 dollars worth in change.
Old Nov 19, 2007 | 10:11 AM
Default Re: (blackh23)
Old Nov 19, 2007 | 10:12 AM
Jagan'92's Avatar
pushing down on the seats to remove them, and making money working on the car... both sound pretty backwards, just the way it should be
RacerGirl629
Honda Fit
Jun 24, 2007 07:06 PM
ednyboo
Oct 29, 2006 08:32 PM
alessandro
Honda Fit
May 23, 2006 01:41 PM
optikal_blitz
Jan 29, 2003 02:09 PM
Turtle
Oct 4, 2001 08:23 AM
