JDM & USDM h22a tune up parts the same?
Old Nov 18, 2007 | 01:45 PM
401tuner's Avatar
Default JDM & USDM h22a tune up parts the same?
might sound like a stupid question but ill be ordering a jdm h22a to start my h2b project for next season. And im wondering if i can just buy a OEM timing belt and water pump from honda. Or if i need to buy specific parts seieng it is a JDM engine and not USDM?
Old Nov 18, 2007 | 07:02 PM
Acidcrakker's Avatar
Default Re: JDM & USDM h22a tune up parts the same? (401tuner)
They are the same parts. An H2b Project? What are you building a Civic, or mabey integra from avatar? Try your home fourm Integra or civic.
Old Nov 18, 2007 | 07:04 PM
mgags7's Avatar
Default Re: JDM & USDM h22a tune up parts the same? (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">They are the same parts. An H2b Project? What are you building a Civic, or mabey integra from avatar? Try your home fourm Integra or civic.</TD></TR></TABLE>
If he is asking h22 questions, he's welcome here.
90% of H22 parts are the exact same from here to japan, the thermostats are a definite difference, among other small things, but as far as timing components and water pumps, you're fine.
Old Nov 18, 2007 | 08:10 PM
401tuner's Avatar
Default Re: JDM & USDM h22a tune up parts the same? (mgags7)
yes i am building an H2B and swapping it into my 98 GSR but i figured id ask you guys because im sure you have the most knowledge about H series. I cant wait
Old Nov 18, 2007 | 08:43 PM
drbenne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">90% of H22 parts are the exact same from here to japan, the thermostats are a definite difference, among other small things</TD></TR></TABLE>
How different? Is there a special place to get thermostats for a jdm engine?
Old Nov 18, 2007 | 11:11 PM
donger's Avatar
Default Re: JDM & USDM h22a tune up parts the same? (drbenne)
all i did was go to Honda and got a thermostat for a 92-96 H22 and it fit in my JDM H22 just fine
Old Nov 19, 2007 | 02:33 AM
mgags7's Avatar
I'm not sure what the stipulation is honestly with the thermostats, I got one that ended up working just fine, but some people either have bigger tstats on their jdm engine or the parts store gives them something much too small....
I'm thinking it may be that AT h22s have the different size thermostat, but I can't be sure on that....
Old Nov 19, 2007 | 03:54 AM
v4lu3s's Avatar
RTFM
About half the time with imported engines I need to bring in the thermostat to match since going by part numbers it does not fit from the dealer.
Everything else is the same except the internal vs external coil distributor cap.
Old Nov 19, 2007 | 05:36 AM
Default Re: (v4lu3s)
Well I had to do a H23a1 swap to h22a and there was a bunch of parts that had to be swapped out to make it easier.
Took Off H23a1 and put onto h22a
1. Manual tension conversion
2. Fuel Rail
3. Top Radiator Thermostat(it had a sensor on it I needed)
4. Dizzy
Old Nov 23, 2007 | 07:20 AM
vlang29's Avatar
The thermostat housing is different, my O-ring was leaking where the Water pipe fits into the t-stat housing. Bought a USDM one from the local dealer, and it was probably 1/2 inch too small diameter.
brotherparker
Jun 1, 2009 04:36 PM
All Mighty
Nov 27, 2007 06:18 PM
401tuner
Nov 20, 2007 01:02 PM
BoostdRex
Aug 28, 2007 02:41 PM
alleyezonme
Jun 14, 2004 08:54 PM
