mini me
i know there have been many threads on this topic and i searched for it. but all the threads i came across where just problems with the swap or a d15 motor questions
i have a 98 coupe with the stock motor (d16y7) and i am doing the y8 swap. right now i have the new head and y8 intake mani. i know i need to get a vtec ecu but is it worth buying a p28 and a jumper harness (car is OBD2) or just buying an ex ecu? and what other parts do i need only to finish the project. i have asked friends and i keep getting different answers.
help is GREATLY appreciated. thank you
WELL YOUR GOING WITH A Y8 HEAD RIGHT? THEN EVERY THING SHOULD BE PLUG IN AND PLAY, AND IT'S BETTER TO GET THE OBD1 P28 ECU AND JUMPER, IT HAS LESS SENSORS AND LESS PROBS. AND AS FOR HEAD AS LONG AS YOU USING THE Y8 MANIFOLD YOU'LL BE OK. ALSO YOU HAVE TO WIRE UP THE VTEC. BUT YOU CAN FIND THE PIN OUTS AT THE TOP OF THIS FORM, IT'S BEEN A WHILE
so all you have to do it take off the head, put the new one on, wire up vtec and switch ecu's...
i thought it was more complicated then that
does any one know of a DIY thread of this swap
ok it's been a while, if you want to get a step by step, go to http://www.d-series.org/ good luck
dirvin7588
Apr 17, 2011 07:53 PM
Hatchdude
Jun 30, 2005 01:37 PM
