Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rear Camber Question for street use / and some raod racing
Old Jun 24, 2002 | 04:12 PM
tjtruong's Avatar
New User
Default Rear Camber Question for street use / and some raod racing
I just got my car back from alignment shop and the rear camber is set at -1.40 . I told him to set it negative to try to see if it'll eliminate the excess oversteer i've been experiencing. I decided to try it out like this. My question is .. does anyone else have a similar rear camber setting as this with stock suspension? I've noticed it does corner better, but still want to know if anyone has had problems with tire wear and such and if this camber setting would be ok for street and track. -1.40 is still within specs according to the mechanic there, but it is the max negative he would go. BTW, i have the rear camber kit for those wondering how i'm adjusting it so easily. Any input would be appreciated. Thanks people!
Thomas
Old Jun 24, 2002 | 07:56 PM
krshultz's Avatar
Default Re: Rear Camber Question for street use / and some raod racing (tjtruong)
I never noticed any problem at 1.5 rear on the street. Not enough weight back there to matter, I suspect.
Old Jun 24, 2002 | 08:02 PM
tjtruong's Avatar
New User
Default Re: Rear Camber Question for street use / and some raod racing (krshultz)
so -1.40 is ok for the street? Thanks man
Old Jun 24, 2002 | 08:03 PM
Cheap Bastard's Avatar
New User
tire pressure. come out to the next autox and we'll get your car hooked up.
David
Old Jun 24, 2002 | 10:35 PM
tjtruong's Avatar
New User
Default Re: Rear Camber Question for street use / and some raod racing (Cheap Bastard)
David
ok no problem david...... i'll hold you to that hahhah
tj
VTECROAR96typeR
Jan 30, 2010 08:59 AM
acmoc
Dec 1, 2008 03:58 PM
2000turbosi
Suspension & Brakes
Mar 26, 2006 08:24 AM
BrownGSR
Jul 7, 2004 07:47 PM
itr1236
Sep 24, 2002 06:18 AM
