all you electronic ppl HELP!
Old Nov 17, 2007 | 08:09 PM
freeflyinrider's Avatar
Default all you electronic ppl HELP!
ok so i wired up my sidemarkers to the turn signal wire(simple splicing and whatnot)
PROBLEM- when i turn the car on they work if im not givin it gas,but the second i start going,it blows the fuse,what do i need to do so it doesnt do that.im not to electronic savvy
thanks!!
Old Nov 17, 2007 | 08:54 PM
Default Re: all you electronic ppl HELP! (freeflyinrider)
come on guys!!!
Old Nov 17, 2007 | 08:55 PM
BUDtoker's Avatar
WHAT???? explain a bit more please i dont understand
Old Nov 17, 2007 | 08:56 PM
BUDtoker's Avatar
Default Re: all you electronic ppl HELP! (BUDtoker)
maybe you got a short, did you try a slightly biggger fuse
Old Nov 17, 2007 | 09:07 PM
ok i spliced the sidemarker wires into the turn signal wires,so they would come on when i put on my blinker.now i did it and they worked fine just testing them out when i wasnt moving.the second i start moving and givin gas,it blows the fuse and my blinkers dont work.
the fuse is a 7.5 and i even tried a 10 and it still blew it
Old Nov 17, 2007 | 09:26 PM
BUDtoker's Avatar
recheck you connections and make sure everthing has good contact! up the amps to 15 if it dont work(not recomended but can be done)
Old Nov 18, 2007 | 09:52 AM
bump for all the views but no bumps
Old Nov 18, 2007 | 12:01 PM
jdmracer12's Avatar
sounds like a bad ground to me.
Colby Schwedes
Honda Ruckus and Scooters
May 31, 2019 06:02 PM
racingcrx
Aug 8, 2008 07:50 AM
1992acurainteg
Jul 27, 2007 07:40 PM
vnguyen850
Mar 4, 2007 07:53 AM
mike93eh
15
Mar 19, 2005 10:45 PM
