B18 LS SWAP in 97 EX civic (EK) help!
Old Nov 17, 2007 | 07:37 PM
xapathyx's Avatar
Default B18 LS SWAP in 97 EX civic (EK) help!
Im sure this has been covered and ive searched for a step by step instructional, or just anything that will help me complete my project but, i seem to be stuck on what mounts to use and what ECU to use/wiring harness, or just anything i need to know about the wiring part to get up and running, so if anyone has some input please help!! my motor is being built right and i want this to be a clean and easy swap ( not that i wont come across some things that will be a hassle) i just need some help people its my first swap!
Old Nov 17, 2007 | 07:56 PM
[JDM]James's Avatar
* B A N N E D *
Default Re: B18 LS SWAP in 97 EX civic (EK) help! (xapathyx)
Use EM1 (1999-00 Civic si) mounts, as for the wiring just get a p75 ecu (obd 2 LS) and it just plugs right up and start it.
Old Nov 17, 2007 | 08:01 PM
xapathyx's Avatar
Default Re: B18 LS SWAP in 97 EX civic ([JDM]James)
what about the wiring harness its OBD 1 on the motor(the B18) and the car is OBD 2 do i just use the OBD 1 harness ? or is that possibal?
Old Nov 18, 2007 | 09:31 PM
jeef84's Avatar
Default Re: B18 LS SWAP in 97 EX civic (xapathyx)
Use an OBDI engine harness. Life will be easier.
Old Nov 19, 2007 | 04:20 PM
xapathyx's Avatar
Default Re: B18 LS SWAP in 97 EX civic (jeef84)
what im confused about is what runs from the motor to the ECU
like do i use the OBD1 harness that fits my B18a ?
and then after that what does it run to ? i doubt it will tie in with the plug leading back to the ecu ?
to narrow it down how will i hook up the new OBD1 harness to my existing wiring on my EK (97 civic EX)
Old Nov 19, 2007 | 06:33 PM
Andres-eh2's Avatar
Please disregard what other people have said besides the mounts, that's partially true.
Use the harness that came with your car. you will need to only extend a few plugs like o2 sensor. you cannot use an obd1 civic or integra harness because those engine harnesses do not have the ECU plugs that go all the way through the firewall.
As for mounts, you need the driver side EM1 bracket and block mount, rear EM1 "L" bracket (i believe) and a 94+ b series front tranny mount. the top tranny is stock civic.
It is the same as swapping any bseries motor in your car except for vtec. search!!!
Old Nov 19, 2007 | 09:59 PM
xapathyx's Avatar
Default Re: (Andres-eh2)
so my D16 wiring harness will hook right up to all the sensors on the b18B1 head ?
the b18b head is obd1 (if im not mistaken ) and my cars obd2 how would that work ?
and what about using hondata ECU to tune with
Old Nov 19, 2007 | 10:12 PM
xapathyx's Avatar
oh yea and its gonna be NON VTEC
Old Nov 20, 2007 | 02:25 PM
adamrg85's Avatar
go to the FAQ section for you car, scoll down to motor swaps and there is a link to a detailed obd2 to obd1 motor swap thread. you will find out every thing you need to know. I just completed a similar swap but my car is a 98 ex coupe and I swaped in a jdm obd1 b16. most people will tell you its hard and just get a obd2 motor but its really simple, i did my in less than a week and it was my first swap. so good luck to you
Old Nov 21, 2007 | 10:55 AM
xapathyx's Avatar
Default Re: (adamrg85)
ive searched .. you have a link that i can get to something like that, i cant seem to find anything that im looking for
Old Nov 21, 2007 | 03:22 PM
adamrg85's Avatar
here is the link, hope it works.
https://honda-tech.com/zerothread?id=1972711
Old Nov 21, 2007 | 03:40 PM
adamrg85's Avatar
go to honda-tech home page, then click on (honda civic/del sol (1992 - 2000), on the next page click on (NEW FAQ'S INDEX - 92-00 civic/ del sol) this page will have nearly everything you need about your car so bookmark or add it to your favorites. just scoll down to swap information and click on the link (obd1 engine into a obd-2 civic or integra. this is by far the best how to for your kind of swap. oh yeah when you do a search on this site dont only searched in the recent content, also search in the archived content which will give you better results.
sLoWrAcEr
Mar 2, 2005 05:21 PM
Jlo96Hatch
Jul 19, 2004 10:03 AM
Midwestrider
Oct 29, 2002 04:12 AM
JoshM
Oct 9, 2002 01:27 AM
jdmekcivic2eg
Mar 20, 2002 06:50 PM
