JDM B18C-R Into '92 Integra....
Allright, I'm about to order my engine but I wanted to make sure I know everything first. I was wondering if anyone has done this swap or has knowledge about it. I'm planning on using my obd-1 ecu with an OBD-2 to OBD-1 converter. As for the transmission, I'm going to get a cable to hydro conversion to maintain the LSD and Hydraulic transmission. I know I have to add the 3 wires for VTEC and 1 wire for the knock sensor. Anything else that I need to know? Thanks for your help and time!
You're going to need either a P61 or OBD-I P72 ECU. Just get a 92-95 GSR distributor and reuse your injectors and you're basically set. Looks like you know what to do with the VTEC wiring. As for the trans., just pick up a 92-93 GSR trans. which has the same gearing as the ITR only w/o the LSD. For more info check out the VTEC swap guide at http://www.g2ic.com
