dropped in the f22b. no start. ideas?
Old Nov 17, 2007 | 01:21 PM
glazethatj's Avatar
Default dropped in the f22b. no start. ideas?
well i dropped in the f22b today. everything went good until i tried to start it. all i hear is a clicking. when it does it the abs light comes on on the dash. i dont see why the abs light would come on. i hooked up all the abs sensors, and the fuses are good. also there was a clicking in the engine bay but i found out it was an a/c relay. the only things i didnt hook up were:
iat sensor cuz its broke and i dont have a replacment yet
p/s pressure sensor cuz i took p/s out
knock sensor cuz there isnt one on the engine, and i got an ecu from phearable so it shouldnt matter
02 sensor cuz that plug is broke
and some a/t trans plugs cuz i swapped a 5 speed in
i dont think any of those would allow it not to start. the headlights work so im assuming the battery is good, but maybe its not charged enough to start it. everything else is hooked up. starter, alt, fuel. idk what the problem is. any help is appreciated
Old Nov 17, 2007 | 02:24 PM
mgags7's Avatar
Sounds to me like either a weak battery or a bad starter.
Try slamming the starter with a blunt object some, then try again.
Old Nov 17, 2007 | 02:30 PM
glazethatj's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds to me like either a weak battery or a bad starter.
Try slamming the starter with a blunt object some, then try again.</TD></TR></TABLE>
well the starter is brand new so hopefully its the battery. ill pick one up and try that
Old Nov 17, 2007 | 06:09 PM
glazethatj's Avatar
Default Re: (glazethatj)
bump
Old Nov 17, 2007 | 06:35 PM
Giant_Bean's Avatar
clutch interlock switch? or since you had an auto, neutral safety switch?
Old Nov 19, 2007 | 04:05 AM
glazethatj's Avatar
Default Re: (Giant_Bean)
bump. put a new battery in and nothing. neutral safety switch is disabled. any other ideas or anything?
Old Nov 19, 2007 | 04:10 AM
mgags7's Avatar
Have you checked through the grounds?
Are you sure the battery negative-&gt;chassis-&gt;trans ground is there?
Old Nov 19, 2007 | 06:24 AM
glazethatj's Avatar
im pretty sure the grounds are good. ill check though. the thing is the lude is 40 mins away at my uncles
forevermemorabl
Aug 26, 2013 05:26 PM
Poroshok
Feb 1, 2010 05:12 AM
shadohc
Mar 3, 2009 02:30 PM
DVS Luder
Nov 24, 2004 12:41 PM
Ben18C
Aug 28, 2004 09:37 PM
