Injector #1 and #4 not flowing as much as 2 and 3
Old Nov 17, 2007 | 08:18 AM
Nashville's Avatar
* B A N N E D *
Default Injector #1 and #4 not flowing as much as 2 and 3
what could my problem be? i know this is the reason of my rough idle. i have obd1 si civic injectors.
b18c1
JDM itr pistons
stock Gsr cams
head shaved .010
completely rebuilt engine
stock exhaust, PWJDM kevlar intake
Blox IM
dont know if you needed that, but i dont know what could be causing that problem
also when i switch out those injectors with 2 and 3, it still has bad flow in 1 and 4. so i know the injectors are good.. just dont know whats causing it,.
Old Nov 17, 2007 | 09:23 AM
B20Monster's Avatar
Default Re: Injector #1 and #4 not flowing as much as 2 and 3 (Nashville)
wait.. how do you know it isnt flowing as much as cyl #2 -#3? get the car up to temp, and do a leakdown test first to see if all the cyls are sealed. then start diagnosing some more.
Old Nov 17, 2007 | 09:29 AM
Nashville's Avatar
* B A N N E D *
i took the fuel rail off with the injectors connected, and turned the key on. 2 and 3 were strong! and 1 and 4 werent.. i warmed the motor up and did a compression check im 280 give or take 2 or 3 all across the board. the engine currently has 468 miles on it.
Old Nov 17, 2007 | 09:58 AM
2fastGSR's Avatar
King of the One Liners
correct me if i am wrong but isnt that called injector pulse? They all dont spray 100% at the same time. Only when the piston in that cylinder comes TDC.
I always thought you needed to flow test or have a management system to see how the injectors were spraying
Old Nov 17, 2007 | 11:50 AM
B20Monster's Avatar
Default Re: Injector #1 and #4 not flowing as much as 2 and 3 (2fastGSR)
i dont know about the whole injector flow problem. but i guess recheck the basics. check to see how the spark plugs look, and gapped, ignition timing, good grounds, and possibly any vacuum leaks. also make sure you didn't plug the wrong connectors onto the sensors. try all those first.
Old Nov 17, 2007 | 12:19 PM
night's Avatar
Default Re: Injector #1 and #4 not flowing as much as 2 and 3 (B20Monster)
semi broken wire(s) in harness? not enough voltage?
Old Nov 17, 2007 | 03:02 PM
mtber's Avatar
Could be an issue with your ecu, wiring harness, etc.
Old Nov 17, 2007 | 03:17 PM
Nashville's Avatar
* B A N N E D *
Default Re: Injector #1 and #4 not flowing as much as 2 and 3 (mtber)
I'm thinking its an ecu problem also. Or proper tuning. Ive done everything listed above. All the basics
Old Nov 19, 2007 | 05:07 PM
A.E Motoring's Avatar
get them flow tested, if u think they are clogged, that will tell u for sure
Old Nov 24, 2007 | 02:32 AM
SJersey's Avatar
Default Re: Injector #1 and #4 not flowing as much as 2 and 3 (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">get them flow tested, if u think they are clogged, that will tell u for sure</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1951304
http://kgparts.com/index.php?page=fuelinjectclean
Old Jan 22, 2008 | 08:55 AM
swaytec360's Avatar
clean and flow test them
Old Jan 22, 2008 | 09:04 AM
mar778c's Avatar
Community Builder
Community Influencer
X3 with Sjersey
Old Jan 22, 2008 | 09:55 AM
Nashville's Avatar
* B A N N E D *
Default Re: Injector #1 and #4 not flowing as much as 2 and 3 (mar778c)
fixed it. it wasnt my injectors, thats the advice a guy gave me. my cams were bad
SwappedTURBOegg
Aug 30, 2007 08:23 PM
vtgearhead
Apr 29, 2007 09:57 PM
all-mtr-teg
Apr 14, 2007 07:34 AM
verizon521
Mar 12, 2007 09:21 PM
strepto
Feb 9, 2004 03:28 PM
