bleeding brakes....
Old Nov 16, 2007 | 07:26 PM
jvaughn's Avatar
Default bleeding brakes....
ya I bought a 1994 del sol. Bought a B16A2 swap for the car last week...right now am at a stoping point taking the motor out... I had to put the rotors back on after taking them off, I went ahead and drain all fluids from the car... well right now I need to know how to bleed the brakes... thanks people....
Old Nov 16, 2007 | 07:40 PM
homemadeturbo's Avatar
Why did you drain the brake fluid, especially if you don't know how to bleed the brakes?
Old Nov 16, 2007 | 07:44 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (homemadeturbo)
https://honda-tech.com/zerothread?id=1918628
Old Nov 16, 2007 | 07:48 PM
1baddturbosi's Avatar
Default Re: (Archidictus)
oops, hope u didnt drain all the fluid out of the master cylinder!!
Old Nov 16, 2007 | 07:49 PM
Unceasing Measure
Default Re: (1baddturbosi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddturbosi &raquo;</TD></TR><TR><TD CLASS="quote">oops, hope u didnt drain all the fluid out of the master cylinder!! </TD></TR></TABLE>
That would certainly require a lot more effort, as it would need to be removed and bench bled. Still, nothing a couple hours can't fix.
Old Nov 16, 2007 | 07:57 PM
jvaughn's Avatar
what do I do guys? help please...... I had to drain it to take out the axles to do the swap....thanks for the help.
Old Nov 16, 2007 | 08:02 PM
Default Re: (jvaughn)
fyi, always keep the master cylinder full with brake fluid.
Now, u need to remove the master cylinder from the car & bench bleed the master cylinder, install back on the car, then begin bleeding the brakes.
Old Nov 16, 2007 | 08:34 PM
sql_civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvaughn &raquo;</TD></TR><TR><TD CLASS="quote">what do I do guys? help please...... I had to drain it to take out the axles to do the swap....thanks for the help.</TD></TR></TABLE>
No reason to drain the brake lines or even disconnect the brake lines to remove the axles. Just leave it all connected and remove the caliper and hang it from the spring or set it on an upsidedown pail (which is what I do).
Old Nov 16, 2007 | 09:36 PM
Burnt Toast's Avatar
Default Re: (sql_civic)
Holy ****, he thought he had to drain all the brake fluid to remove the axles and he's going to try swapping an entire engine? WOW, good luck dude .
mrspeedy69
15
Aug 5, 2013 02:57 AM
AnthonyG2003
Jul 24, 2005 11:37 AM
DIY_Racing
Feb 3, 2005 06:56 AM
robbin
Apr 26, 2004 01:53 PM
aesthetics82
21
Jan 13, 2004 03:15 PM
