Fuel Injectors
Old Nov 16, 2007 | 12:52 PM
adeline's Avatar
Default Fuel Injectors
I am going to be converting a hf motor to e85 and I need to know if the zc fuel injector would be big enough to run e85 in my hf motor or do I need bigger with a tune.
thanks
Old Nov 16, 2007 | 02:53 PM
adeline's Avatar
Default Re: Fuel Injectors (adeline)
so body on tis whole forum can answer a little question like this
Old Nov 16, 2007 | 03:04 PM
SIred91's Avatar
Rainman
Why would you need a bigger injector anyway?
Old Nov 16, 2007 | 03:51 PM
adeline's Avatar
Default Re: Fuel Injectors (SIred91)
it take 20 too 30% more e85 vs regular fuel. that is why you need bigger injectors
Old Nov 16, 2007 | 04:01 PM
mr.speaker's Avatar
well if you have a 90-91 hf its the same 240cc that most honda motors use
edit-but i see in your sig you have an 88 hf,those only have ~180cc injectors
Old Nov 16, 2007 | 04:04 PM
njn63's Avatar
Default Re: Fuel Injectors (mr.speaker)
I'm pretty sure H22's had 310 CC injectors which would be just under 30% larger than 240's.
I hope you have other ways of tuning this though outside of dropping in bigger injectors.
Old Nov 16, 2007 | 04:21 PM
adeline's Avatar
Default Re: Fuel Injectors (njn63)
i plan on chipping the ecu and get a wide band too.
I dont want to run half and half I want to be able to run one or the other
Old Nov 16, 2007 | 04:23 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adeline &raquo;</TD></TR><TR><TD CLASS="quote">i plan on chipping the ecu and get a wide band too.
I dont want to run half and half I want to be able to run one or the other</TD></TR></TABLE>
Look into the moates two-timer (i think that's what it's called).
If you're going to be tuning it, i'd just find a set of DSM injectors. The auto ones are fairly cheap and are 370 CC's which would be enough i'd think.
ben222
Aug 27, 2007 11:04 PM
sporkcrx
Oct 21, 2006 01:07 PM
Hulud
Aug 21, 2006 12:45 AM
b16powwer
Aug 15, 2003 12:07 AM
WONG FRIED RICE
Jul 15, 2003 10:52 AM
