integra front knuckle/brake assembly question.
Old Nov 16, 2007 | 09:00 AM
instrument's Avatar
Default integra front knuckle/brake assembly question.
(the story)
Ok, so i finally got around to installing the front arms from a 98 integra onto my 94 hatch(vx).
After putting on the drivers side assembly, i noticed it was sort of tilted in and towards the front, as if it has a ton of camber and the toe was awful.
at first i suspected it to be the upper arm, so i swapped it with another, and i have the same result.
my only other thought is that the front arm is bent. (any other opinions?)
(the question)
Is the front arm/knuckle on the 93 style integra the same, or will i need the front arm/knuckle from a 94-01 integra?
I ask this because i know where i can get the arm/knuckle from a 93 integra nearby (i live in the woods), and i was hoping i could simply bolt up the caliper bracket and caliper that i already have on (and that i've already bled) from my 98 integra, and swap over the hub from the 94-01 which i've already pressed my new lugs into.
i've searched and i know the assemblies will FIT onto my car, but I don't know if the caliper/bracket/hub will bolt onto it, making my life a little easier.
thanks.
and here's a picture, since people are more likely to post on threads with the img thing
Old Nov 16, 2007 | 03:52 PM
BlueIntegraBoy's Avatar
Default Re: integra front knuckle/brake assembly question. (instrument)
Any suspension from the 90-93 Integra will not work, except for struts. Get the arms and knuckles from the 94-01 Integra. The front LCA could be bent. If you plan to add the arm just to use a sway bar, I suggest only swapping the "A" portion and leaving the stock "I" portion. It's faster.
Old Nov 16, 2007 | 06:17 PM
instrument's Avatar
i already have the sway bar on, and i was thinking the lca could be bent, and i have one from an integra, but i figured if the LCA was bent then i would've noticed before swapping out the new knuckle assembly.
if the LCA was bent don't you think the three bolt's that go to the A-arm would've been off?
it does seem rather unlikely that the control arm would be bent, seeing its so f'n thick..
2slowIntegraLS
Aug 5, 2016 02:16 PM
instrument
Nov 16, 2007 11:36 AM
LSEGHATCH
Sep 26, 2005 10:15 PM
fastest
Feb 16, 2005 11:16 AM
phantom_sol
Sep 28, 2003 01:25 PM
