Discs In The Rear W/O Integra Arm
Are there companies making rear conversion kits for our eg/ek's w/o having to use an inegra control arm and brake assembly? Or do you have to get the Integra Assembly and then swap that out for aftermarket calipers/rotors/etc.....?
If you don't understand what I'm asking I can try and explain it better.
You don't need the integra arm. All you need is the brake assembly that attaches to the arm. It's a pain in the *** to take it out but it's the less expensive alternative.
Re: (civic_driver)
Ok but do I need to get the Integra assembly first and then upgrade it or are there upgrades alread out there that eliminate the need for the Integra assembly?
Re: (LSEGHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH »</TD></TR><TR><TD CLASS="quote">Ok but do I need to get the Integra assembly first and then upgrade it or are there upgrades alread out there that eliminate the need for the Integra assembly?</TD></TR></TABLE>
All you need is the trailing arm w/ brakes attatched, and e brake cables. NOTHING else.
Re: Discs In The Rear W/O Integra Arm (LSEGHATCH)
Not necessarily looking for a "BIG" brake kit, but instead to upgrade the rotors/pads/and calipers in both the front and rear.
You need everything Dr. ****** said. That would make things easier. If you want to go cheaper and a little harder, you can replace everything in that list except the trailing arm. In this case, you will have to remove the drum assembly from the trailing arm and put the disc assembly on. It's a bit more involved but you don't have to pay extra for the rear trailing arms.
Good luck!
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH »</TD></TR><TR><TD CLASS="quote">Are there companies making rear conversion kits for our eg/ek's w/o having to use an inegra control arm and brake assembly? Or do you have to get the Integra Assembly and then swap that out for aftermarket calipers/rotors/etc.....?
If you don't understand what I'm asking I can try and explain it better.</TD></TR></TABLE>
AEM made a rear disc convertion kit. But it's way over price.
94allmotor
18
02-06-2009 01:09 PM
Civicman86
04-29-2007 07:49 AM
phantom_sol
09-28-2003 01:25 PM
