code 22
Old Nov 16, 2007 | 06:15 AM
allmotor2.1's Avatar
Default code 22
Have code 22 from ecu and want to know what it means and how to fix it.
Old Nov 16, 2007 | 07:12 AM
logg_frogg's Avatar
Default Re: code 22 (allmotor2.1)
Try the search option, it works wonders if you change it to archived threads
https://honda-tech.com/zerothread/1901557
this link should help.
Code 22 is VTEC Pressure Switch.. there are about 12 million threads about it on here.
generally the problem is that your oil level is too low and the switch is not getting proper oil pressure delivered to it
top up your oil, clear the code and see if that helps!
if it doesn't remove the housing that the switch is housed in. there is a fine mesh screen and some cavity's that should be thuroughly cleaned. Reinstall, clear codes, and try again.
if it still doesnt work check the wiring to the switch....
generally the switches arent bad but it is possible
Old Nov 17, 2007 | 05:01 AM
Default Re: code 22 (logg_frogg)
Thanks for the help those tips were very helpful
vtec-civic1089
Honda Civic (2001 - 2005)
Apr 12, 2007 02:46 AM
spoonfedGSR
Sep 26, 2003 02:31 PM
Snail Tuning
Sep 26, 2002 05:39 PM
boost killz
Jul 15, 2001 12:24 PM
